Old 12-24-2005, 03:49 AM   #1
Mounting the BU-353
Mounting the BU-353
Not as in trying to ride the thing but as in where to put it!
As it is magnetic do you need to stick it to sheet metal (like a cb antenna) or not?
Next, If not, do you need to mount it flat for it to work best?
The simplest place for me to stick mine is on the back of some gauges that are ontop of the dash.
So, i would be gluing it to a plastic cover, about 1" behind the windshield, 1" up from the top of the dash and it would be much the same angle as the glass (not sat flat like the top of the dash)
It would have a 180deg view of the sky.
Also, to get your direction (n/s/e/w) which part of the unit should point to the front of the car or will it only work out heading once you start moving?
Thanks!
PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
hotponyshoes is offline   Reply With Quote
Old 12-24-2005, 04:25 AM   #2
Fox_Mulder's Avatar
I have mine flat on the dashboard:
You can see a pic of it on this post
http://www.mp3car.com/vbulletin/show...54&postcount=4
On the back of those gauges should work fine, only way to know is to try it!
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353
Fox_Mulder is offline   Reply With Quote
Old 12-27-2005, 02:19 AM   #3
I have mine in the back of the car on the inside, under the rear speaker deck cover, somewhere in the middle. No reception problems and you can't see it
DaPCWiz is offline   Reply With Quote
Old 12-27-2005, 02:29 AM   #4
seanz0rz's Avatar
direction of the reciever doesnt matter, it tells your heading by comparing 2 data points.
its magnetic so you COULD stick it to sheetmetal, not required tho.
mine sits directly in the center of my dash, pushed all the way against the windshield
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline   Reply With Quote
Can't get the BU 353 to work with Destinator plugin inniss777 Centrafuse 2 11-24-2005 03:56 PM
Mounting a 700tsv ninjatill LCD/Display 4 10-07-2005 12:47 PM
Mounting amp and PC under seats? omehegan Fabrication 11 08-21-2005 04:21 PM
How do I stick mounting tabs to a tinted rear windshield?? hd54321 General MP3Car Discussion 7 03-31-2005 03:13 PM
Methods of mounting? MP3DUB General Hardware Discussion 6 10-01-2002 06:40 PM
