Old 01-01-2006, 01:15 AM   #1
GPS giving wrong coordinates!
I have a rather unusual problem that started when I was trying to import POIs over wireless networks in my hometown kirkenes in norway. I am using mapmonkey and netstumbler with xport to split com-signals. Everything works fine with mapmonkey giving me the right coordinates, but netstumbler says that my wireless network at home is some 34km away. I discovered this when i was trying to use nmeaGE and google earth, and the map showed that i was in russia. That could problarbly give me some problems when they see my log-file and they ask for a valid visa for the trip or maybe it could give me a perfect alibi
anyways, does anyone know what could be wrong? could it be xport? i find it weird that mneaGE and netstumbler get wrong coordinates, and mapmonkey get correct coordinates at the same time. Have attached a pic with netstumbler log and the poi from my house with the correct coordinates. HELP PLEASE!
bmw318ISCoupe is offline   Reply With Quote
Old 01-01-2006, 02:44 AM   #2
You haven't ****ed off any major governments lately, have you?
Something like that means an algorithm wasint copied right or corrupted. This was a project in some people in my linear algebra classes did (they created and analyzed the GPS matrix algorithms. Don't ask me, i did matrix encryption). Install it on another PC and see if the same thing happens. Its the only way. Its amazing what one wrong bit will do to a complex calculation!
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline   Reply With Quote
Old 01-01-2006, 10:38 AM   #3
Those co-ordinates aren't that far apart...
69° 41.564' = 69.69273 29° 59.694' = 29.9949
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 01-01-2006, 12:27 PM   #4
Not so far away, no, but 34 km misguidance could give me a problem when i am trying to find a wireless network
could it be xport messing up the coordinates? anyone wxperiences the same?
Old 01-01-2006, 12:52 PM   #5
Curiosity's Avatar
XPort doing what?
No way!
Run netstumbler with XPort and look at the coordinates, then run it again without XPort, connecting directly to the GPS. You should see the same exact values. If not, tell me.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 01-04-2006, 01:34 PM   #6
Sorry Cur!
Its not xports fault, in the pic you see that mapmonkey and nmeaGE has the right coordinates, and netstumbler has got the wrong coordinates. When I tryed to not use xport, only netstumbler, it gave the exact same coordinates as before. There must be something wrong with netstumbler i guess...
what could it be?
Old 01-04-2006, 03:43 PM   #7
Curiosity's Avatar
The GPS output is in degress + 2.3 places for minutes. When converting time to degrees some programmers round and some don't so there will always be a small difference. I wouldn't think that's a big deal.
Old 01-04-2006, 04:10 PM   #8
Raw Wave
Rob Withey's Avatar
what could it be?
Those coordinates are pretty much the same. One is expressed as degrees, one is expressed as degrees and minutes:
69.6621383333333 degrees = 69 degrees 0.6621383333333*60 minutes = 69 degrees 39.72829999999 minutes.
29.982055 degrees = 29 degrees, 0.982055*60 minutes = 29 degrees 58.9233 minutes.
Rounding explains the very small discrepancies as Curiosity said.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 01-05-2006, 09:51 AM   #9
Ahh, I see! Thanks for the help!
So if I want to write the coordinates from netstumbler expressed as degrees n minutes in just degrees, you just take the numbers after the point, and divide it with 60?
Something like this:
69 degrees 39.728299999 minutes =
69 + (39,728299999/60) =
69 + 0,662138333 =
69,662138333
Is there a web page or app that does this automaticly, or is there a option in netstumbler to show the coordinates as degrees?
Old 01-05-2006, 04:06 PM   #10
DeltaFX's Avatar
Officially, NEMEA coords are in dddMM.mmmm
ddd :degrees (can be 1, 2 or 3 digits long)
MM is a fixed-length number of minutes
mmmm is 1/10000 of a minute.
To convert to degrees :
DD:= Trunc(DM /100.000000);
MM:=DM - (DD*100.000000);
DD:=DD + (MM/60.000000);
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
Alturion Professional Advanced GPS 6 - The New D3 ? Is There A SDK ? ccsnet GPS 91 11-07-2006 05:47 PM
garmin mapsource and usb gps mouse thecrow GPS 9 09-26-2006 03:24 PM
GPS coordinates of police spots (speedtraps) for North America inside blaster GPS 25 06-24-2006 10:42 PM
OEM GPS Modules. IntellaWorks Hardware Development 91 03-08-2005 07:29 AM
Newbie's guide EBFoxbat Newbie 6 02-08-2005 11:06 AM
