Old 02-27-2006, 01:19 PM   #16
LESLIEx317537's Avatar
I have been using XPort3 for 2 weeks now. Great program.
Using it with my USB BR355 to help it out of hibernation.
One thing though, since it enables us to use more than one GPS app, I decided to try to play with my spare GPS Rx I have lying around.
I got some VB6 code to work with it, then I tried VS2005 using the .NET v2.0 Framework that has a new SerialPort Class.
When I run the .NET serial port program with XPort3 and the .NET program uses the new SerialPort class it doesn't work. I then shutdown XPort3 and it works off the normal com port.
If I use MSCOMM from VB6 in my .NET app, then it works fine by not using the new Serial Port class, but the old way...
Weird. Also how hard would it be to add a Line to the GPS sentences. Cause some proprietary GPS send out sentences, and I wanna have my Old Co-Pilot 2003 work with my new BR355, but I noticed it's not spitting out this extra line that my other GPS does.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Old 02-27-2006, 11:11 PM   #17
Curiosity's Avatar
If you want to send me an app that uses the new serial port class, I'd be happy to take a look at what it's doing (or not doing). I could probably add some code for compatibility. Not sure about adding a fake sentence though.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 02-27-2006, 11:15 PM   #18
Super Moderator
xBrady's Avatar
What exception is being thrown when you try connecting using VB.net?
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Major Electrical Problems techy101 Off Topic 14 07-11-2005 10:47 AM
DWW-700M/MTS12000 Motorized In Dash LCD Problems techy101 LCD/Display 17 06-29-2005 08:12 PM
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 05:04 PM
Dell Inspiron 8200 & Lilliput TS problems? bkpsu LCD/Display 1 08-15-2004 02:55 PM
Some warnings about Deluo Routis 2004, MapPoint 2004 & XPort dumpper GPS 13 07-15-2004 01:07 AM
