Old 01-03-2006, 12:52 PM   #1
Cheekz185 will become famous soon enough
Xport 3 problems
OK wel i am trying to set up Xport3 with my GPS. I downloaded Xport 3 and the Compass. My GPS port prior to using Xport is Com9. I am trying to split the port into to.
This is what my xport screen looks like:
Now whenever i try to connect to comports 8 or 10 in iguidance nothing happens. And the compass, i set it to com 8, 10 and 9 but i get no data. Before i splitted the com ports the compas was reading data on com9
How do i fix this?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 01-03-2006, 12:59 PM   #2
lez
lez's Avatar
lez is on a distinguished road
has your gps moved from com9 ?
I had it lose data because my usb/serial gps moved from 4 to 3
lez is offline   Reply With Quote
Old 01-03-2006, 01:13 PM   #3
Nope it didnt move, in device manager is still stays com9
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 01-03-2006, 01:24 PM   #4
kbreeden
Check Curiosity's Xport threads. I remember reading that there's a problem with IGuidance when the com port has double digits. Since one of your ports is 10 that may well be the problem.
kbreeden is offline   Reply With Quote
Old 01-03-2006, 01:26 PM   #5
But the compass still does not get any data as well...
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 01-03-2006, 01:32 PM   #6
kbreeden
I've struggled with configuration of RR/IG/Xport myself, though I do have everything finally running properly. I don't know enough about it to help other than to mention that I do recall there being a problem with using double-digit com ports.
Old 01-03-2006, 01:38 PM   #7
ok well i switch all my com ports, input is on COM 2 and output is COM 6 and 7 but i get nothing still....
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 01-03-2006, 01:39 PM   #8
What should the baud rate be?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 01-03-2006, 02:46 PM   #9
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Open hyper terminal and connect to the GPS COM port to see if you have data coming thru.
If there is data coming thru, on the bottom of Xport windows, you will see the same type of data.
BTW, just make sure that the GSP COM port works before you said it xport problem (it may have other problem but not this problem).
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 01-03-2006, 02:46 PM   #10
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Form the screenshot it looks like something is connected to COM9 so XPort can't access it. You will see a little green dot next to the input port like COM10 shows and see NMEA data at the bottom of the window when it's correctly connected to your GPS.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 01-03-2006, 02:46 PM   #11
lez
lez's Avatar
4800
Old 01-16-2006, 05:00 AM   #12
Chewster is on a distinguished road
I'm having problems with XPORT and standby/hibernation. The program works great for the most part; reconnects to the port, etc..; cept it crashes on resume like 95% of the time. I know it's meant for USB comports, but I'm using it on a bluetooth dongle with widcomm 1.4.2. I just don't understand why it crashes on resume. So any help to fix or to go about diagnosing the problem would be greatly appreciated.
Thanks and excellent program btw.
ps. I'm running RR, iGuidance, DLink BT w/widcomm 1.4.2
Chewster is offline   Reply With Quote
Old 01-16-2006, 08:16 AM   #13
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
NOTHING to do with this thread. Dont thread-jack. ANd if port 9 is the correct port and there's data was coming from the gps you'd see a green dot by com9 and the NMEA data streaming at the bottom of the box. You need to test your gps without xport. Once ur sure its working properly then add xport back in.
Old 01-16-2006, 02:34 PM   #14
Well, the thread title is "Xport 3 problems" so I thought I'd report the problem in here also. Anyhow, my apologies...
Old 01-16-2006, 07:24 PM   #15
Curiosity's Avatar
Well, that's exactly OT. I don't know what would be wrong with it though. Bluetooth should work, but XPort probably gets impatient with it since it takes a few seconds to connect. Do you know how long it usually takes? Like 5 or 10 seconds? And as far as crashing, can you give me an error code or anything?
Major Electrical Problems techy101 Off Topic 14 07-11-2005 10:47 AM
DWW-700M/MTS12000 Motorized In Dash LCD Problems techy101 LCD/Display 17 06-29-2005 08:12 PM
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 05:04 PM
Dell Inspiron 8200 & Lilliput TS problems? bkpsu LCD/Display 1 08-15-2004 02:55 PM
Some warnings about Deluo Routis 2004, MapPoint 2004 & XPort dumpper GPS 13 07-15-2004 01:07 AM
