Old 01-04-2006, 05:05 PM   #1
GPSlim 236 Problems
Ok gusy so i finally completed my install today well for the most part. I booted the pc in the car everything loaded and was great. My GPS worked and everything. But then i shut down the PC, my sister came home and she wanted to see it so i started up and Next thing you know My GPSlim 236 becane an unknown device. There was a message saying that this device has malfunctioned and blah blah blah. But now when i plug the gps in i get no more unknown devices and it doesnt even acknowledge that i plugged it it. It is a usb connection. But all the light are working on the gps even the green light. But i get i was getting an unknow device but now i get nothing... i have no clue what the problem is. I dont understand why it was working fine when ui was conguring everything in my house and the first time i started the pc in the car. I dont know if it mite be the usb cable or what. But I tried plugging it into my friends comp and it didnt recognizr it as well, Can the usb cable just go bad like that?Can i pick up one of these usb cable at a local store??
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 01-04-2006, 06:15 PM   #2
Marvin Hlavac's Avatar
I would try to:
1. Unplug it from your PC
2. Start > Settings > Control Pannel > System > Device Manager
3. Look up the GPS receiver under "Ports"
4. Right-click it > select Uninstall
5. Restart PC
6. (do NOT plug the GPS yet)
7. Insert the CD that came with your GPSlim236
8. Install the driver software
9. Plug it in now
10. If still no luck, plug it to another USB port
The cable is really not just a cable, but it is a USB/Serial adapter, so you cannot use an ordinarry cable which has USB connector on one side and mini-USB on the other.
Marvin Hlavac is offline   Reply With Quote
Old 01-04-2006, 07:07 PM   #3
Quote: Originally Posted by Marvin Hlavac
I would try to:
But see here is the thing, it is not even listen under ports i already did that....I gotta go get the cd and try that. I downloaded the drivers from holux's website:
http://www.holux.com.tw/Temp%20web/d...ta.html#GR-230 But it is just an .exe. I dont know if those are the exact drivers. But hopefully the cd will work!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 01-05-2006, 04:20 AM   #4
ramy_zohair's Avatar
I had this device, but gave it up for garmin. The usb cable that comes with the package is not for data. it is just for charging. you have to get the special usb cable if you want to connect it through usb, otherwise use bluetooth.
"Together with the usual multi-country charger cable system and the ability to charge the battery from three different sources, this GPS continues its predeccesors success. Don't forget that this GPS can still be connected via both Bluetooth and a wired cable (available separately) simultaeneously."
https://www1.securesiteserver.co.uk/...218edba5cd5693
Hope this helps
ramy_zohair is offline   Reply With Quote
Old 01-05-2006, 11:12 AM   #5
Hope this helps
The cable I am using at the moment is the one provided by HOLUX, but it doesnt seem to work when connecting to any computer anymore so i ordered a new cable.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 01-05-2006, 04:41 PM   #6
I checked the link you provided, buy it didn't work. I found a driver (also exe) here: http://www.holux.com.tw/Temp%20web/download-data.html and I ran it on my home PC. It works. Try it to see what happens ;-)
The (correct) cable desn't come in standard package. It is an optional cable which has to be ordered extra. It is about $19.
The cable which is included with the standard package indeed will not work for your intended purpose. It is only good for charging (via USB).
(...but you have said it worked for a while... so I'm confused what cable you really have...)
Old 01-05-2006, 08:38 PM   #7
I have the $19 one. The serial to usb one
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Holux GPSlim 236 Help ramy_zohair GPS 8 12-07-2005 01:37 AM
Still having XMPCR problems rjoek RR Bug Tracker 15 09-23-2005 02:08 PM
DWW-700M/MTS12000 Motorized In Dash LCD Problems techy101 LCD/Display 17 06-29-2005 08:12 PM
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 05:04 PM
Dell Inspiron 8200 & Lilliput TS problems? bkpsu LCD/Display 1 08-15-2004 02:55 PM
