03-01-2006, 06:46 PM
#76
Registered User
Vehicle: 04 Infiniti G35 Coupe
I got around to making a map with a valid confoguration file for u-center and had it plot me on it
The plot is PERFECT. Everything is dead on
Blue indicates singal loss and DR, green indicates 3D lock
In DR I was plotted correctly which is exciting. The loss of signal on the bottom part of the map were trees blocking view and the one at the top was the freeway overpass. Unfortunately CoPilot just didnt plot me the same way. Argh. Still yet to test other GPS programs but will report back
03-01-2006, 06:52 PM
#77
MySQL Error
Vehicle: Pug 306 & BMW 325i
looking good, now go somewhere to give it a proper test.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
03-01-2006, 06:56 PM
#78
Raw Wave
Location: Spagcave, in da UK Today's phrase: J'aime Alizee
Vehicle: Spagwagon------ Status: Big Avatar King
We need someone to get this and demo it at the meet.....
03-01-2006, 07:02 PM
#79
MySQL Error
the meet is in an open field
03-01-2006, 07:16 PM
#80
Raw Wave
And....? I'd still like to see it close up
03-02-2006, 05:38 AM
#81
Vehicle: 2001 Jeep Grand Cherokee Limited
Well I'm almost done with my unit! Will start testing by next week I hope. BTW aoLhaTer CoPilot is very picky on the gps input. I have a hard time using it with serial port splitter programs also. Are you guys using direct feed from the speed pulse line of the car? Just tap it?
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
03-02-2006, 09:42 AM
#82
Registered User
Ed Reily at Ublox has advised me to turn off all the extraneous NMEA messages being sent and only send RMC, GGA and GSV
Seems to make sense; if the program is getting more data than it can handle its going to freak out
03-02-2006, 09:49 AM
#83
MySQL Error
Vehicle: 2002 Dodge Ram 1500 Quad Cab
Yeah that does make sense
03-02-2006, 05:08 PM
#84
Vehicle: 2008 Lincoln Navigator
The best way to test it is in NYC;  which means that I can do it for you..
Let me know if I can buy one off of you
03-02-2006, 05:18 PM
#85
Registered User
Im actually going to San Francisco tonight and will be testing
Last time I was there my GPS lost all signal downtown; was completely lost. Hopefully better results this time
03-03-2006, 01:51 AM
#86
Registered User
I have discovered the solution to 3rd party software not playing nice with the DR functionality
In order for DR to work in 3rd party applications YOU MUST "enable position output even for invalid fixes". This option is found in u-center under View->Configuration View->NMEA
(I also enabled position output even for masked fixes but not quite sure what that means)
With that option enabled the guidance programs always think that theres a GPS signal even if there's not one (ie in DR mode). Worked excellently in CoPilot. San Francisco test through downtown worked flawlessly
Unfortunately my problem now is that the backup battery is dead!! This is the second one to die, I need to recheck the circuit. So now none of my settings get saved and it takes 45 seconds to get a sat lock from cold start
03-03-2006, 06:30 AM
#87
MySQL Error
45 seconds!!!! my bu-303 takes about 5 minutes!!!
03-03-2006, 11:02 PM
#88
made the circuit but it doesn't work!....  must recheck everything. I hope my board is not defective! And wanted to test during the weekend... going for a trip to NY... will try to get it working before saturday morning... I followed Laidback's circuit. I used a terminal to see the port output and I could see some output but it did not make sence. Some dollar signes mainly, no NMEA sentences
03-04-2006, 03:47 AM
#89
Registered User
What were you using to test? HyperTerminal? Tried u-center?
What MAX chip are you using?
03-04-2006, 09:01 AM
#90
yes HyperTerminal. I did try U-center but it didn't see anything on the port. I used the MAX233cpp and serial port 1.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
