Old 03-04-2006, 06:39 PM   #91
MobiTekLink's Avatar
Quote: Originally Posted by spaceskater
made the circuit but it doesn't work!.... must recheck everything. I hope my board is not defective! And wanted to test during the weekend... going for a trip to NY... will try to get it working before saturday morning... I followed Laidback's circuit. I used a terminal to see the port output and I could see some output but it did not make sence. Some dollar signes mainly, no NMEA sentences
If you go to NY the worst place for signal is in the Financial district (Wall street) Midtown is not so bad but around Madison Avenue and that should give you the best testing conditions.
2004 GMC Yukon Denali
www.myspace.com/mobitekny
http://www.flickr.com/photos/bustadreamz
MobiTekLink is offline   Reply With Quote
Old 03-05-2006, 08:49 AM   #92
spaceskater's Avatar
Thanks MobitekLink, I will definitely be testing it! the good part is that my plans changed a bit so I will be going to NY on Tuesday and stay for 6 days so this is a great opportunity for testing! I am sure my girlfriend will not be so happy about it... driving around just to test my GPS... shopping is her priority! lol
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
spaceskater is offline   Reply With Quote
Old 03-15-2006, 03:04 AM   #93
Well I'm back from NY. I got a chance to test the GPS and for the most part I got very good results. For navigation it works VERY well. I was in DR mode for most of my driving in Manhattan an it performed very good. I used MapMonky (Destinator) and CoPilot, both worked well.
I logged data with U center but haven't yet processed it. I want to compare them with an actual map but I haven't had the time to figure out how to do it yet. if anyone has a map of NY that I could use in U-center I would really appreciate it! Now the bad part. Initially I used it without a backup battery so it had to lock on satellites initially to start tracking with DR, otherwise it had no idea where I was, but in Manhattan it's not always easy to do so.
Then I installed the battery but to my surprise every time I turned the car and computer on, my position was a bit off, usually a few miles wrong! Using U center to monitor the GPS output I figured out that after I turn off the ignition the speed input from the car changes erratically! So for the 90 seconds that it takes my power supply to turn off after my ignition is off, my position would change a lot due to this problem. I thought of two solutions. first I could power the GPS from the ACC line so when ignition is off so is the GPS so change in the position. Or I could use a relay to disconnect the speed input so I would still have the GPS connected to the computer. Say you stop for gas, you don't want your Nav program loosing gps connection. But then again it's not such a big deal is it? I think I'll go with the first idea.
One more problem I encountered is that the Ublox has some incompatibility issues with Goops. For those that don't know what Goops is go here:
http://www.mp3car.com/vbulletin/user-innovations/68799-goops-google-earth-gps-tracking-navigation-new-gpsgate-mologogo-tracking.html
so I could not test the input directly to a Google Earth map... That would give me a very good sense of how accurate DR is. Here in Boston when my GPS has a good lock I'm almost always on the right position on Google Earth. ON the road and usually on the correct side too! so the maps are accurate for Boston at least. I heard some people complain that for there place GE was a bit off. When I get the time I will run it on GE with DR to test it.
Well that is all for now! Sorry for the long post...
Old 03-15-2006, 03:35 AM   #94
BTW this is my Ublox GPS. I included a power supply so I can power it from any thing. The silver heat sink hides the voltage regulator. I installed it outside so the heat would not affect the gyro or the temp sensor of the board. Well also I know by board is messy but it works Hope I could do a nice printed circuit board...
here are the photos!
Old 03-15-2006, 09:45 AM   #95
Hi Spaceskater,
I would be interested in any problems your having using GooPs with Ublox. Let me know if I can help.
Thanks and keep up the good work.
davidhite is offline   Reply With Quote
Old 04-04-2006, 06:44 AM   #96
I belive my original incar navigation system that came with my Car does have a DR GPS.
Does anyone know if the GPS module included inside a TravelPilot RGN08 is usable on a PC? Everything is soldered in so I cant just remove it.
I replaced my Travelpilot indash screen with a 7" lilliput, and the nav unit with a MiniITX, so I could just shop up the Navigation unit to remove the GPS.
Cirion is offline   Reply With Quote
Old 04-04-2006, 07:03 AM   #97
Technical data
Basic navigation unit 8 618 841 994
with integrated gyro, GPS receiver and CD-ROM player
- Rated voltage (Urat) 14 V DC
- Rated current (I) Typically 0.55 A (Imax 1.05 A)
- Stand-by current Typically 0.35 A
- Speech output/volume Max. 3 Watt/4 Ohm
- Time to first position computation (Warm start, memory refresh) < 2 minute; (cold start, memory clear) < 15 minutes
- CD-ROM drive For 12 cm CD to DIN EN 60908 only
- Operating temperature -15°C to +60°C
- Mounting orientation Horizontal/+5°
- Width 184 cm
- Height 73 cm
- Depth 171 cm
- Weight 1.9 kg
Old 04-04-2006, 07:22 AM   #98
Can this be used?
http://www.tycoelectronics.com/prodnews.asp?ID=757
Old 04-04-2006, 01:56 PM   #99
Quote: Originally Posted by Cirion
This very interesting. I don't see why it wouldn't work!
Old 04-04-2006, 03:22 PM   #100
http://www.tycoelectronics.com/gps/pdf/A1030Aflyer.pdf
Old 04-04-2006, 03:59 PM   #101
Banned
RPM_VR4's Avatar
Did you see this one: http://www.tycoelectronics.com/gps/DR1030.asp
I have just requested a free sample. Wish me luck
RPM_VR4 is offline   Reply With Quote
Old 04-05-2006, 01:45 AM   #102
Woot, that looks like a finished product
Hope it cost less than the uBlox demo kit... 1199€ is more than I would pay if I got 10 kits....
Old 04-05-2006, 04:18 PM   #103
Banned
RPM_VR4's Avatar
Quote: Originally Posted by RPM_VR4
The demo kit can be had for $435. PM me if you want the purchasing info (please only PM if you are ready to spend the $435 right away, I don't want my box to fill up with request for info from people that would never spend that cash [like me ]).
Old 04-06-2006, 12:16 AM   #104
This one is just 60$...
Old 04-06-2006, 12:33 AM   #105
That is incredibly cheep compared to the Ublox going for $199.00!!! And they appear to have the same functionality. I might just get one to see if it works well. My Ublox works very well until now. I am sure the we can set it up very easily now with all the experience from Ublox.
Alturion Professional Advanced GPS 6 - The New D3 ? Is There A SDK ? ccsnet GPS 91 11-07-2006 05:47 PM
GlobalSat BT-338 Review tom2112 The Review Palace 8 06-27-2005 12:02 PM
Newbie's guide EBFoxbat Newbie 6 02-08-2005 11:06 AM
D3 with USB GPS after HIBERNATION BOND007BE Map Monkey 7 11-26-2004 02:54 PM
Rand Mcnally GPS, Dead? zootjeff General Hardware Discussion 5 09-19-2001 03:31 PM
