Old 01-10-2006, 12:20 AM   #1
doublet's Avatar
Serial vs. USB receiver
which one is better (pros and cons)? i've read many threads but none helped me choose. what do you recommend?
doublet is offline   Reply With Quote
Old 01-10-2006, 12:25 AM   #2
Raw Wave
EsKALad's Avatar
serial has less issues with hibernation. no drivers required also.
i got dat ***** sittin on 22s! SUPERMAN EDITION!
EsKALad is offline   Reply With Quote
Old 01-10-2006, 12:25 AM   #3
doublet's Avatar
specifically, i was planning to get the bu-353 or bu-355. i have the sp13000. both type of ports are available. i just can't choose.
Old 01-10-2006, 12:26 AM   #4
Raw Wave
EsKALad's Avatar
i just ordered the br355
Old 01-10-2006, 12:39 AM   #5
doublet's Avatar
thanks for the reply. will xport3 eliminate the hinbernation issues? i notice that a lot of sites, such as mp3car.com and buygpsnow.com, doesn't carry the bu-355. is that receiver going away?
Old 01-10-2006, 12:40 AM   #6
Raw Wave
EsKALad's Avatar
because its called a BR 355 not BU
Old 01-10-2006, 12:40 AM   #7
Raw Wave
EsKALad's Avatar
i just ordered a 355 from buygpsnow.com 2 days ago
Old 01-10-2006, 12:41 AM   #8
doublet's Avatar
oh my mistake
Old 01-12-2006, 10:27 PM   #9
MobiTekLink's Avatar
I've tried both and I use serial, although there is the extra wire to the PS2 for power I would really use that instead of the side issues that I have found with USB.
1. USB has to be on the same port, otherwise if you switch you'll have to reinstall or re-scan the receiver. The lock on the serial assures that it is safe from moving, and if you use another power source by splitting the wires you'll get a better connection than the PS2.
2. Power issues, it seems to take longer to power up, my USB receiver is never ready when I come back from hibernation, I have to wait sometimes 2 mins.
3. Speed, there is no advantage in using USB over serial, NONE!.
2004 GMC Yukon Denali
www.myspace.com/mobitekny
http://www.flickr.com/photos/bustadreamz
MobiTekLink is offline   Reply With Quote
Old 01-13-2006, 10:36 AM   #10
MySQL Error
MatrixPC's Avatar
If you can, go with serial. Less problem, and less headache.
I have USB receiver and never have problem with hibernation when running on it own virtual COM port. I do have problem with xport3 once in a couple fullmoon in my matrix setup. Kill and restart xport3 and all work fine. Never have problem in the Supra setup.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 01-13-2006, 05:02 PM   #11
Dont get me wrong, itz not that USB is totally useless,,, but compared to serial you'll have about 3 issues to deal with if you were to use USB over serial.
As far as I'm concerned there are almost no side issues with serial. No drivers, less start up time, no hibernation issues... Hands OFF!
For me those are enough not to ever use a USB GPS receiver, the time that'll I use a USB receiver is when they start selling receivers with "Dead Reckoning" incorporated....
Old 01-13-2006, 06:20 PM   #12
doublet's Avatar
i went with your advices and ordered the br-355 (serial). the box came with a receiver with only a ps/2 port coming from it. they also gave me an extra ps/2 to USB adapter. isn't there suppose to be a y-cable coming from the receiver (one is mouse serial and one is ps/2)?
Old 01-14-2006, 12:03 PM   #13
No dude,,, all it needs the ps/2 port is to draw power.
You can take that ps/2, strip the cable, and +/- it to your HDD or Floppy connector and have it more secured like that.
Or if you wanna be real "cool" you can hard wire it to the battery, with a 12v-5v adapter you can have the GPS "always on" so there are no warm up issues and itz always locked on to satellites.
;0
If you use the ps/2 to usb adapter you'll be dealing with the same issues as if you were getting a USB GPS.
The only issue you "might" have is that the GPS gets confused to be a mouse; but there is a simple solution if you search on the forums...
Old 01-14-2006, 01:47 PM   #14
DeltaFX's Avatar
There are some industrial motherboard that have serial port witha 5/12v pin.
This one does http://www.ibt.ca/IB880.htm
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
Old 01-14-2006, 03:23 PM   #15
COM2 (RS-232/ RS422/RS485)
You mean that? How would that be useful to us? would we need a different adaptor or configuring the wiring differently?
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Lirc serial to usb problem woeful Input Devices 0 04-26-2005 07:12 PM
usb IRDA dongle - emulate serial? xdjxklusivex Input Devices 3 04-20-2005 06:08 PM
Had anyone seen / used this Rikaline 6020 USB Receiver? Vacheron GPS 0 01-28-2005 03:24 AM
GPS Receiver - USB -vs- Serial Daz GPS 6 06-24-2003 05:56 PM
