Old 01-31-2006, 09:25 PM   #1
rjoek is on a distinguished road
GPS time zone sync
Has anyone tried software (preferably free and reliable) that will sync the Windows XP system clock with NMEA time output from GPS receiver?
I'd appreciate any comments. Looking for something very simple that runs in the background. Thanks!
rjoek is offline   Reply With Quote
Old 01-31-2006, 10:11 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
I didn't know such software exists.
Why would you even bother with this? Is your PC's clock not keeping accurate time? Is the on-by-default network time synchronization built into WindowsXP not accurate enough?
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 01-31-2006, 10:15 PM   #3
When I change time zones I need to update the time as such. And I don't typically use NTP in my car computer. I don't care so much about the accuracy of the time (to the minute/second) as I do about the hour.
I should have been more clear: what I really want to do is change the time zone, not the hour.
Look at http://www.topshareware.com/GPS-Time...load-39576.htm (first result from a Google search)
Old 01-31-2006, 10:29 PM   #4
Ahhh. I misunderstood.
Again, I didn't know such software existed, but it certainly seems like a good idea if you drive cross-country a lot.
Old 02-01-2006, 12:29 PM   #5
wi77iam's Avatar
wi77iam
This should be fairly easy to do. Just grab the time from the nmea string and use it to set the system time. I'll give it a go if I find some free time (no pun intended).
wi77iam is offline   Reply With Quote
Old 02-01-2006, 01:27 PM   #6
Marvin Hlavac's Avatar
Marvin Hlavac will become famous soon enough
Time can be synchronized with NMEA Time ( www.visualgps.net/NMEATime ), but I'm afraid they forgot to include the time zone synchronization (perhaps you could request a new feature ;-)
Marvin Hlavac is offline   Reply With Quote
Old 02-01-2006, 01:33 PM   #7
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
IIRC dragonbtv created software like this.
0l33l is offline   Reply With Quote
Old 02-01-2006, 03:56 PM   #8
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Is there a list of coordinates for each timezone somewhere on the net that could be used to do this?
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is online now   Reply With Quote
Old 02-01-2006, 04:19 PM   #9
Thanks for the comments. Did some looking, and the share(free)ware stuff out there can also use GPZDA, which allows time zone sync, but this string is not commonly output for consumer USB GPS devices, such as my Rayming TN-200. Looks like there are a few that do but I would need to buy a new one.
A database of timezone coordinates is therefore not needed, unless the more common output is used. Might be more complicated though? Is there an easy way to sync the time zone using just GPGGA?
Old 02-01-2006, 06:48 PM   #10
Curiosity's Avatar
GGA just has UTC (GMT) time, so it's the same everywhere. It's very easy to use since SetSystemTime() can take it without conversion. I do that in my compass app. I'm not even sure that you can set the timezone programatically. It would be nice though.
Old 02-01-2006, 07:03 PM   #11
My Village Called
0l33l's Avatar
http://www.mp3car.com/vbulletin/dragonbtvs-carpc-plugins/35299-dragonbtvs-carpc-plugins-master-thread.html
Old 02-01-2006, 08:26 PM   #12
Quote: Originally Posted by 0l33l
How does this adjust my time zone?
Curiosity, thanks for the comments -- yes, it is possible and there are a number of program that do it, using the GPZDA string. Unfortunately my GPS unit doesn't output that (see above).
Old 02-01-2006, 08:27 PM   #13
My Village Called
0l33l's Avatar
download it and see
Old 02-01-2006, 08:55 PM   #14
download it and see
I did.
Still not seeing.
Old 02-01-2006, 09:00 PM   #15
My Village Called
0l33l's Avatar
I did.
Still not seeing.
Ask for it in the features request.
Garmin announces Mac GPS support for everything! skizot MacCar 11 01-31-2006 04:37 AM
My GPS scenario & Bluetooth quest. gizak GPS 13 04-12-2005 01:11 PM
Delorme Street Atlas 05 quick review cash_Money GPS 7 12-13-2004 08:31 PM
D3 with USB GPS after HIBERNATION BOND007BE Map Monkey 7 11-26-2004 02:54 PM
gps tripmate position time? schrodos General Hardware Discussion 7 11-29-2000 02:21 AM
