Old 02-14-2006, 10:42 AM   #1
Smokemaximus's Avatar
Delorme LT-20
Do not buy this POS GPS reciever. Just came back from a trip and this thing is the most unreliable POS I have seen. Granted I havent had anything else but Just when I needed it the most it loses signal. Right before I would need to turn it would lose Sats and then I would be like WTF!. Luckily I had a trusty old fashion paper map. I need the most reliable dash mount antenna thats out there. I hear the Sirf star iii sp? Is pretty good. Please advise. Also I drive a 2005 nissan maxima. My guidance was Iguidance 2.1.3 and also delorme 2006. Delorme 2006 sucks as well. Advice is appreciated
Smokemaximus is offline   Reply With Quote
Old 02-14-2006, 11:22 AM   #2
muldrick's Avatar
Thanks for your advise. Are you sure the placement of the antenna is ok, try moving it around. Seems unlike that DeLorme would sell a unit that does not work. Maybe try different locations???
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 02-14-2006, 11:53 AM   #3
05MaXSL's Avatar
I have had no issues with the signal quality using my LT-20. I have my unit located on the reardeck. Where is yours located?
edit
I have 20% tints covering my rear glass.
Check out my install pics; http://mp3car.com/vbulletin/showthread.php?t=70842
05MaXSL is offline   Reply With Quote
Old 02-14-2006, 03:00 PM   #4
MySQL Error
MatrixPC's Avatar
The LT-20 is NOT the same as the old Earthmate USB (now sale as pro).
And I have to agree that it is SUCK compare to the "pro".
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-14-2006, 03:51 PM   #5
Legarcondemerde's Avatar
I agree. I have one of these in one of my vehicles, a Rikaline 6010 in the other, and the Rikaline ****es on this hunk of crap. And the Delorme software still shows street/highway names that are at least ten years out of date for my area.
Legarcondemerde is offline   Reply With Quote
Old 02-14-2006, 05:05 PM   #6
the LT-20 is horrible. the drivers arent bad though, built in com splitter and decent monitors, still no need. also, bright yellow?
d2.n is offline   Reply With Quote
Old 02-14-2006, 05:16 PM   #7
I have tried different areas on the front window. My rear is metalized tint So I cant put it on the rear shelf. I works great sitting still but start moving then its a whole different story. Takes too long to acquire new sats.
Old 02-14-2006, 06:28 PM   #8
susuking's Avatar
i'm using mine okie,
it's still okie
Progress Bar: [//////////]100%
Have M10000, 40gb 2.5"hdd, i guidance, wireless,slim slot drive, delorme gps, roadrunner, liliput touchscreen, opus150w ...
all fabrication done...
susuking is offline   Reply With Quote
Old 02-15-2006, 07:33 PM   #9
wow, can't believe i'm hearing this. i've had this receiver w/iguidance work flawlessly for over 6 months now.
took it from VA ---> PA and back with no problems (even through PA's mountains)
i have mine on my rear deck w/35% tint.
only problem i have is sometimes when boot from being on hibernate, the computer doesn't recognize the receiver, i simply have to restart, and the problem is fixed.
to op: must be something wrong with your setup. hopefully you figure it out.
fventura03 is offline   Reply With Quote
Old 02-15-2006, 07:48 PM   #10
No the led constantlly blinks red. I will be driving along and boom it loses sats, weither im driving straight or turning. POS.
Old 02-15-2006, 07:49 PM   #11
where is it mounted?
Old 02-15-2006, 10:49 PM   #12
front dash
Old 02-15-2006, 11:25 PM   #13
susuking's Avatar
mine is on the front dash too, so, maybe some setting is wrong i guess, mine works well, no prob all the way to vegas
Old 02-22-2006, 03:48 PM   #14
Master X's Avatar
I despise this thing. I have not gotten a signal the ENTIRE time I have had it. It got a signal ONCE when I was outside the car at a car meet. I was grabbing something inside the car and noticed it had a fix. Got back in the car to start moving and it didnt have it anymore. Haven't been able to get a fix since.
Master X is offline   Reply With Quote
Old 02-22-2006, 06:18 PM   #15
Yeah its a POS. I just bought a Bu-353 sirf star. Hopefully it will fix all my problems.
Switch from delorme to iguidance Smokemaximus GPS 1 02-02-2006 10:55 AM
delorme software replacement? fortressgame GPS 20 11-10-2005 07:48 AM
TT Sirius USB interface Pyrotek General Hardware Discussion 0 09-08-2005 08:15 AM
iGuidance with Delorme USB Receiver muldrick GPS 23 12-12-2004 07:30 PM
can the Opus stay powered up indefinately for STR? ie: no shut down after 20 minutes? pooshda Power Supplies 3 05-28-2003 09:45 AM
