Old 02-22-2006, 07:09 PM   #1
royandrews is on a distinguished road
DIY GPS Housing
I'm not sure whether to put this thread here or in fabrication.
Anyways, I'm probably going to be putting my GPS (a BU-353 when it arrrives) outside my car on the roof. However, I'm not a fan of having a $100 GPS ripped off the roof of my car by curious thugs. The same goes for my 7.5db WiFi antenna.
So I came to the idea of building a custom housing for them. My plan is to make a "fin"-like thing out of abs or some other plastic with a flattened piece at the front to hold the gps inside and a short sticky-uppy bit at the back to cover the base of the WiFi antenna.
Like this:
+++++++++++++++V
+/+/--------\++ ___|__+\
|+|+ GPS ++|+ |+WiFi +| |
|+ \_______/+ |_______| |
Edit: DAMN forum removing white space. Please ignore the +'s above.
Now, I was wondering, will a couple mm of ABS will affect the performance of my gps? Would it help if i took it out of it's stock housing first (don't worry my housing will be waterproof).
Also, will munting the WiFi and GPS in close proximity cause the GPS to lose performance?
Any suggestions are very welcome.
royandrews is offline   Reply With Quote
Old 02-22-2006, 10:22 PM   #2
Registered User
aoLhaTer's Avatar
aoLhaTer
GPS will generally pass through plastic without a problem
2004 G35 Coupe project
aoLhaTer is offline   Reply With Quote
Old 02-22-2006, 11:01 PM   #3
Thanks.
What about the nearness of the WiFi antenna?
Old 02-22-2006, 11:48 PM   #4
kiltjim's Avatar
kiltjim is on a distinguished road
This question came up before, and from what I remember it was never settled. You can search, but I think this is an accurate recap:
1: It'll wreck your signal. I tried it, and it did.
2: No it won't. I did it, and it works fine.
1. Yes it will, you don't know what you are talking about.
2: No, it won't. [louder]
1. Oh, I guess you're right.
1. Dumbass...
Oh, and there might have been some math, and some discussion of wavelengths, and harmonics in there too.
So, does that help?
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 02-23-2006, 01:20 AM   #5
Quote: Originally Posted by kiltjim
So, does that help?
Not in the slightest actually
I did search and read up on those topics that mentioned it but some people just like to argue...
I guess I'll just have to try and see. But, to make one out of ABS is a good few hours that I could spend... um, ah, um..... doing ..... um........ nothing.
Anyone got any proof either way in that argument? I can't find any math in any topics. (If someone could give me the specific link to that topic I'd appreciate it).
Thanks.
Old 02-23-2006, 09:20 AM   #6
kiltjim's Avatar
Really? It didn't help? Huh...
But seriously, I just did a quick search, and it turns out that a certain store sells combo antennas. I am not going to link to them, but if they sell them, they have to work at some level. I would have to say that it should work fine.
2000 Subaru OBS
Dell P3 @ 900 Mhz
80GB External HD
Old 02-24-2006, 08:12 AM   #7
Taxi49's Avatar
Taxi49 is on a distinguished road
Lightbulb GPS Limitations
Though GPS can provide worldwide, 3D positions, 24 hours a day, in any type of weather, the system does have some limitations.
Anything shielding the antenna from a satellite can potentially weaken the satellite's signal to such a degree that it becomes too difficult to make reliable positioning. As a rule of thumb, an obstruction that can block sunlight can effectively block GPS signals.
"Wireless-Fidelity (Wi-Fi) 802.11a operates at radio frequencies between 5 GHz and 6 GHz on Ultra Wideband Technology (UWB). In the study released by Stanford University in March 2001, all tests showed the same sensitivity to UWB signal type, and the worst interference occurred when a discrete UWB device operated within the GPS band. Further, the Stanford study concluded, UWB transmissions that overlap or come near to the GPS band must be carefully regulated to ensure that there is no adverse impact to GPS.”
Source:Federal Communication Commission FCC
Having said that.
if you get at least 4 Sat Lock with your MoD housing unit you will be fine.
~__o_\___
=-O----O-'
www.polares.com.au
www.itx.co.nz/index.php
Taxi49 is offline   Reply With Quote
Old 02-25-2006, 08:35 PM   #8
I was only kidding, you've been a great help.
I would be using 802.11b/g for WiFi which uses 2.4GHz instead of 5 - 6 Ghz. I donno about its effects on GPS signals. But, yeah, they make commercial combo antennas so i guess its ok.
I'll post a new thread when I finish it.
Thanks again for the help all.
Old 02-25-2006, 08:41 PM   #9
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
you would be better buying a combo antenna to go ont he roof and wiring this up to the inside of the GPS reciever. if it is anything like the BU-303 it has an active antenna that can be removed and then you can wire up an external active antenna for putting outside. This gets much better results wit the bu-303 - especially when you sort the crappy battery too.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 02-26-2006, 01:41 AM   #10
You mean someone's actually managed to replace the internal antenna successfully? The only cases I could find on this forum were failures (resulted in a destroyed GPS). And I really don't want to waste my very limited funds on something to break.
By the way, what's the difference between the 303 and the 353? I thought the 353 was just the newer version with 20 sats limit instead of 10.
Also, if i put 2 wireless adapters in the car (ie: a WRT54GL router and a normal WiFi pci card) as well as a bluetooth dongle, would I need a dedicated antenna for each, or can the 2 802.11g ones use one and the BT need another, or can they all run on one antenna (if so would I need an amplifier)?
Old 02-26-2006, 05:24 AM   #11
MySQL Error
well the internal antenna is pretty big. look up a thread by jcdillin where he did it on an bu-303
Old 03-13-2006, 12:18 AM   #12
gendatu is on a distinguished road
see here
http://www.mp3car.com/store/product_...roducts_id=148
gendatu is offline   Reply With Quote
Old 03-13-2006, 12:24 AM   #13
My man uses Levitra.
Peoples's Avatar
Peoples is on a distinguished road
that is an antenna....not a gps unit
PC Components:
My work log
Peoples is offline   Reply With Quote
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
My GPS scenario & Bluetooth quest. gizak GPS 13 04-12-2005 01:11 PM
Delou Routis GPS USB install issues, please help... jedi7001 GPS 8 03-26-2005 11:29 AM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 02:34 AM
DIY your BlueTooth GPS dragonBTV GPS 15 09-08-2004 01:56 AM
