Old 02-24-2006, 10:58 AM   #1
Newbie1900 is on a distinguished road
BUB 303 and mapsource
Hi Guys....
I desperately need help with bub 303 and mapsource( garmin).
I have bub- 303 as my receiver connected to laptop(windows 98 SE with 64 Ram).
I have try to connect both item but it doesn't work. I have done everything according to the manual but it still have the same result.
I can see all the signal that have been received with my bub 303 through gps info(program), I assume the gps receiver is working since I can see the signal through gps info but I can't connect with mapsource.When I want to connect with mapsource its say " you need to set interface option on your gps to garmin or host mode" No device were found please make sure your device is connected to the computer and turned on then try again
is there anything else that I can do or I just stuck with the wrong equipment
Please help
Thank you very much
Regards
John
Newbie1900 is offline   Reply With Quote
Old 02-24-2006, 03:01 PM   #2
ptk
ptk is on a distinguished road
John
officially mapsource ONLY support garmin product. it is not a free product per se.
so when you set inferface option, it's actually check if the device connect is a garmin device.
there is ways around it of coz. search for gpsproxy
CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
ptk is offline   Reply With Quote
Old 02-26-2006, 06:23 AM   #3
Thanks PTK for the advice
Regards,
John
Old 02-26-2006, 07:50 AM   #4
Hi Ptk
I have try to install the gpsproxy but I can not run it . It say A required DLL file MSCOREE DLL was not found
Sorry to bother you is there anything that I can do?
John
Old 02-27-2006, 10:11 AM   #5
RawsonDR's Avatar
RawsonDR is on a distinguished road
John
Try updating to the latest Microsoft .NET package (windows update).
RawsonDR is offline   Reply With Quote
Old 02-28-2006, 04:23 AM   #6
Thanks Guys................... for helping me until this stage.
I am having difficulties everytime when I want to try my gps . I don't know May be its me anyway, I start from buying wrong equipment etc.....
Ok let me tell about my tough luck story
It begin from
buying wrong equipment.
I have mapsource as software but I don't know that mapsource only compatible with garmin receiver only.
(PTK)one person came to me says that I can get around with gpsproxy then I install gps proxy(horayyy ))) ) . All when ok until when I want to run it it doesn't show anything it say missing some of windows file. This time I can manage to fixed it.(Thanks to Rawson DR)
The next problem come out again . this time I can run the gpsy proxy but I can not go to tool and setting.It say" QueryDosDevice error # 87 "
I can click detailed and it say:
ee the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: QueryDosDevice error #87
at OpenNETCF.IO.Ports.Streams.WinStream.GetPortNames( )
at OpenNETCF.IO.Ports.SerialPort.GetPortNames()
at GPSProxyPC.FormSettingsPC..ctor()
at GPSProxyPC.FormMainPC.menuItemSettings_Click(Objec t sender, EventArgs e)
at System.Windows.Forms.MenuItem.OnClick(EventArgs e)
at System.Windows.Forms.MenuItem.MenuItemData.Execute ()
at System.Windows.Forms.Command.Invoke()
at System.Windows.Forms.Command.DispatchID(Int32 id)
at System.Windows.Forms.Control.WmCommand(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/MICROSOFT.NET/FRAMEWORK/V2.0.50727/mscorlib.dll
GPSProxyPC
Assembly Version: 1.0.2207.24285
Win32 Version: 1.0.2207.24285
CodeBase: file:///C:/PROGRAM%20FILES/GPSPROXYPC/GPSPROXYPC.EXE
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SerialPort
Assembly Version: 0.7.2145.20010
Win32 Version: 0.7.2145.20010
CodeBase: file:///C:/PROGRAM%20FILES/GPSPROXYPC/SerialPort.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
below the line is what computer saying when I want to go to tool and setting with gpsproxy
About my laptop:
I am running windows 98 ME
My gps receiver BUB303
I use the newest version of gps proxy
I am begging for all of you that have same kind of condition and be able to fixed it to tell me how to fixed this problem or someone one who know how to fixed tell me please how to fixed it Pleaseeeee
Thanks for listening my tough luck story with gps . And I hope this may last problem . Sorry to annoy you guys
email me the solution for my problem
johnsmithie@hotmail.com
Regards,
John
