Old 03-03-2006, 01:38 PM   #1
problem with signal
Hi,
I'm having a problem. Right now I'm using the Holux GM210u gps reciever with IG and roadrunner and xport.
Everything works but the problem i'm having is. It takes a very long time to catch satellites. It shows connection cause I see all that data running, but locking into satellites takes a long time or doesn't happen at all. Doesn't anybody know whats the problem?
99cl is offline   Reply With Quote
Old 03-03-2006, 01:45 PM   #2
I get that with my GM210 as well. I find it helps a lot to power on in a place where you're sure to have a good signal. If I started in a parking garage, wouldnt lock for a half hour. If I start out facing clear sky, seems to pick up a few sats pretty quick.
I hear there's also a driver update for the GM210. Might want to search for it.
rsd212 is offline   Reply With Quote
Old 03-07-2006, 02:18 PM   #3
I updated the driver, but i believe it was the same one. Still having this problem. Thought it might be xport so I stopped it and switched it back. Still the same problem. IT will show all the satelities but it doesn't lock into it.
Does anybody else have another idea what it might be?
Old 03-10-2006, 12:18 AM   #4
figured out the problem. It was the usb extention. Removed it and it works again, which is werid because it was working before.
Old 03-10-2006, 11:06 AM   #5
99cl I am having the same problem. I drove for 25-30 minutes today and as I was pulling into my office parking lot it grabbed a sat as I was parking.
Its weird, it grabs SAT when it wants.
I have a Royaltek Sapphire GPS Mouse Receiver(not sure what the model # is, the newest one) and it has the usb extention on it, I might try it without the extention.
naturalsr405 is offline   Reply With Quote
Old 03-11-2006, 12:33 PM   #6
I am having the same issue with my i guaidance and rikaline 6010 gps mouse
Josh
'04 WRX
aspitfire is offline   Reply With Quote
Not your typical flicker problem JPuma LCD/Display 17 05-30-2007 10:28 AM
Epia MII 1200 and Xenarc = No signal badandy LCD/Display 0 08-29-2005 05:52 PM
3 months of fiddling around and NOTHING!!HELPP!!! outdidya Power Supplies 99 12-23-2004 09:31 PM
Buzz in Sound djXternal Car Audio 13 10-13-2004 10:55 PM
Cell Booster / Amplifier GruvThang General Hardware Discussion 7 07-28-2004 07:35 AM
