Old 03-07-2006, 11:18 PM   #1
0okami's Avatar
powering a BT GPS unit off a USB port. here's how i did it.
Well, I own a teletype Bluetooth GPS unit and I am quite pelased with it. Its going on two years old.
Tired of buying batteries or having to recharge the unit, i figured on modifying it to take power from a usb port.
Attached are the images.
The advantage is quite evident to me. the device can now use power from:
battery (rechargables die out after a while)
dc wall plug (running on an inverter in the car... who wants to carry an inverter?)
cig plug (which i didnt have at the moment...)
usb plug... (i have ports up front on my dash,, might as well!)
I no longer have to rely on an inverter.
I have not actually finished it, but its working. Im trying to figure out a way to make the wire detachable... probably a molex connector of some sort, and stash that into the battery compartment.... hmm...
The wire of the device i used was a usb clip on lamp.
~0okami.Digital
Anime. that's my excuse. What's yours?
2001 Mitsu Eclipse Spyder GT http://ookami.n2-network.com/
MSN Messenger and Gmail: ookami.digital@gmail.com
0okami is offline   Reply With Quote
Old 03-08-2006, 02:27 AM   #2
0okami's Avatar
well, i found a spare barrel jack from a dead phone that was laying around... i decided to use that and make the wire detachable.. but first the gps housing needed modified.
~0okami.Digital
Old 03-08-2006, 02:31 AM   #3
0okami's Avatar
last few...
~0okami.Digital
Old 03-08-2006, 02:38 AM   #4
0okami's Avatar
feeding from a usb port.
~0okami.Digital
Old 03-08-2006, 07:14 AM   #5
wi77iam's Avatar
When it's hooked up, you might want to cover up the word "wireless". Kinda defeats the purpose of having a bluetooth gps, IMO. But whatever fits your needs.
wi77iam is offline   Reply With Quote
Old 03-08-2006, 07:24 AM   #6
Neither darque nor pervert
DarquePervert's Avatar
I gotta agree.
The point of a wireless GPS unit is now lost. You an also tap into 5v on a molex from your power supply.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 03-08-2006, 07:43 AM   #7
MySQL Error
jcdillin's Avatar
Well actually I dont agree in this case, because now yes he has a wired mouse, but he doesnt have the USB issues that go along with the cheap gps mice.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 03-08-2006, 12:32 PM   #8
I'd think that bluetooth connections would be more finicky than USB connections...
My Worklog
Old 03-08-2006, 12:51 PM   #9
0okami's Avatar
i forgot to mention, another reason i did this was because when poweing the teletype from the power box instead of battery, it would have to be restarted a couple times for it to actually activate bluetooth. it was as if the power supply or something was not giving it enough power. sometimes the red light (batt indicator) would come on too...
the wires that feed the power to the gps are soldered to the battery power connectors on the main board. This device has always performed much bettter on battery.
loosing its purpose of being wireless? sure. Thats partially true.
But its usefull when your out of batteries.... i wonder if it will recharge rechargables when hooked up... .hmmm.
~0okami.Digital
Old 03-09-2006, 09:36 AM   #10
wallaceacura's Avatar
I have a GR-231 and I'm in the same boat, however I'm not tapping into the USB port. I plan on wiring another cig lighter in the head liner and plugging the unit in up there to stay always on.
For me, even though its plugged in, the connection is still wireless via the BT. The comp is in the trunk and the receiver is a the front of the car. I didn't have any problems setting up BT. It's really gotten a bad rap, but the Holux at least works great every time. It's probably more dependant on the BT dongle than anything else though.
Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
wallaceacura is offline   Reply With Quote
Old 03-09-2006, 09:37 AM   #11
Thanks for the link. I'll post pictures of mine when I'm done.
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 56 11-16-2008 12:10 AM
Question about USB port 510SX General Hardware Discussion 13 08-18-2005 05:21 PM
USB Serial Port Adapter Troubles bLindmOnkey General MP3Car Discussion 0 10-14-2004 12:29 AM
Will Delorme USB GPS work with Copilot7? DLe GPS 12 09-06-2004 07:34 PM
GPS Receiver - USB -vs- Serial Daz GPS 6 06-24-2003 05:56 PM
