Old 03-24-2006, 05:59 PM   #1
gps unit
hi i got a gps unit off ebay, i wasnt sure what one to buy so i just went to the seller and looked at his feedback from other users on the unit and most said better than expected etc.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN%3AIT&rd=1
i fire up mapstore 3.5 (demo version) to test it put gps parameters in com 3 and 9600 baud, if i click on test i can see 3 things up 4,17,20 but sat - 0 and no fix.. im guessing because it cant pick up any satelites ? is it just the gps thats not strong enough or what?
do you suggest i get another one?
via michelin mapstore seems to be about the simplest gps software to buy? wanted something that will look alright on my touchscreen monitor but not cost alot i.e under £50
aletchet is offline   Reply With Quote
Old 03-25-2006, 02:48 PM   #2
kpjuk's Avatar
Hi Aletchet, and welcome to the forums. This is the right place to get information, a lot of the guys and gals here have years of experience, but be warned, they do like you to find the information yourself, but will generally point you in the right direction. There are a number of NMEA free apps on the web that can test to make sure that your mouse is working. Satellite signals are very faint, and so make sure that the receiver has good line of sight to the night sky.
I have no experience of mapstore, I use Infomap Navigator, but my system is not yet in the car. I have tested it on my laptop for short journeys, but not for anything of any distance.
To get a fix, you need at least three satellites, if you are getting some signals it would suggest you are using the right com port. Have you tried putting the gps mouse outside, with no obstructions to the sky ?
Other than that I can't help you, but I wouldn't buy another one until you know what is wrong with this one.
Good Luck
KPJUK
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
kpjuk is offline   Reply With Quote
A little O/T but I need a hand held GPS Unit sciff5 GPS 4 10-20-2005 05:16 PM
Noob Question: Can you use different mapping software with a DeLorme GPS unit? saskwatch GPS 3 07-18-2005 08:12 PM
Buying a GPS "mouse"/other cheap unit GWRedDragon GPS 5 08-25-2004 10:10 PM
Serial GPS unit, does it use pin 8? LittleDragon GPS 10 04-15-2004 06:51 PM
Opinions on this GPs unit found on Ebay? jakeep GPS 2 09-25-2003 04:30 AM
