Old 03-26-2006, 06:01 PM   #1
srcstc's Avatar
Help: System Hibernation Failed because of COM1 (GPS)?
Every time I try to go to hibernation I get this error. My GlobalSat BR-355 is on COM1. Anyone know a fix?
-Rich
srcstc is offline   Reply With Quote
Old 03-26-2006, 08:45 PM   #2
v8 scimitar's Avatar
use hybernate trigger and write a script to dissable com 1 via microsofts devcon, on the way back up use another script to enable it again. Has worked for me for months now although I have done it via an autoit exe instead of a bat file but it will work either way.
v8 scimitar is offline   Reply With Quote
Old 03-26-2006, 09:33 PM   #3
srcstc's Avatar
So you had this same Problem? Why does it happen?
BTW, I switched to the other COM port and it hasn't done it since.
Rich
Old 03-27-2006, 11:09 AM   #4
Well I am assuming your GPS is USB and win XP is well known for having problems with USB devices in hybernation. One machine I have has no problems and another has but it is exactly the same GPS reciver as in the same one not just same model. Anyway the script sorts it out and is completely transparent.
Old 03-27-2006, 12:11 PM   #5
srcstc's Avatar
It's serial, not USB.
Old 03-27-2006, 05:49 PM   #6
I should have actually realised it was serial being on com 1. I think my solution will still work for you although it isnt the usual problem. I assume you do actually have the latest drivers? You arent sharing it through a com splitter or anything are you?
Old 03-27-2006, 05:52 PM   #7
srcstc's Avatar
I didn't install any driver's cause it's serial. It's been working fine on COM2 though.
Rich
System error skin and mapmonkey gps ? tony_vodka Software & Software Development 0 02-18-2006 03:52 PM
possible gps system? kozman31 GPS 1 03-27-2003 05:24 AM
Explain to me what All i would need to have a GPS system in my car []\/[]aster []D GPS 7 10-13-2002 09:57 PM
GPS software similar to Mercedes system? Phat Justice Software & Software Development 0 08-10-2000 08:26 PM
$60 GPS System! Antenna and software! lifter General Hardware Discussion 9 07-19-2000 09:22 PM
