Old 04-02-2006, 06:09 PM   #1
garmin gps 18 USB-to-Serial bridge driver
hey i have a garmin usb gps 18. i have iguidance installed and cant get it to connect to my usb gps. the iguidance website said that i need a usb to serial bridge driver. does anyone know where i can find the driver? i tried going to the garmin website but they dont have anything in the download section.
killa996 is offline   Reply With Quote
Old 04-02-2006, 06:18 PM   #2
You can use Franson GpsGate to get your Garmin 18 USB working as a serial GPS device that outputs NMEA data. They have a free trial too, so you can see if it works for you before buying. It's quite a handy piece of software, with support written specifically for the Garmin 18 USB.
DylanBennett is offline   Reply With Quote
Old 04-02-2006, 07:16 PM   #3
Neither darque nor pervert
DarquePervert's Avatar
Actually, the Garmin GPS 18 doesn't output NMEA data, which is needed for iGuidance.
I think there's a software that will convert the WAAS data to NMEA. Google for it.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-02-2006, 07:23 PM   #4
I know it doesn't. It outputs Garmin data. Franson GpsGate takes the Garmin 18 USB output data (in Garmin format) and converts it to NMEA data coming out of a virtual serial port.
Old 04-02-2006, 07:31 PM   #5
Does it really? Hmmmm. Interesting.
I have GPSGate that came with my BU353. The BU353 outputs NMEA, so I'm using GPSgate for the virtual COM ports. But that's really good to know.
My Worklog
Old 04-03-2006, 04:01 AM   #6
Marvin Hlavac's Avatar
As far as I know iGuidance will not work with Garmin 18 USB even if you use GPS Gate. Other software may work in such configuration, for example MS Streets & Trips does. IGuidance however requires an NMEA sentence [GGV(?) if memory serves] which at the moment the above mentioned setup does not provide.
Marvin Hlavac is offline   Reply With Quote
Old 04-03-2006, 04:55 AM   #7
If you're talking about the GPGSV sentence, then you are correct, GpsGate does not output GPGSV data from a Garmin 18 USB. (GPGSV is the satellite data.) Why would iGuidance need the satellite data in order to function, though? For navigation, the satellite data is pretty irrelevant. Location, speed, direction, etc. is more what you need for navigation, and all that is provided with the sentences that GpsGate does transmit from the Garmin 18 USB.
Either way, at least GPGSV will be supported in GpsGate 2.0, which supposedly is on its way soon.
Old 04-03-2006, 11:32 AM   #8
Yes, that's the one, GSV ;-)
I recall, about a year ago when GPS Gate 1.1 was released with the Garmin support, an iGuidance user was unable to get it working properly and the makers of iGuidance confirmed GSV sentence was required.
Thanks for the good news about the upcoming GPS Gate 2.0!
Old 04-03-2006, 02:45 PM   #9
yea i tried everything to make my iguidance work with my gamin 18. i get the time and altitude and coordnates but iguidance does not show me on the map. anyone want to buy a brand new gamin gps 18 usb???????
Old 04-03-2006, 03:00 PM   #10
Didn't it come with nRoute? Mine did. Just curious, but what are the advantages of iGuidance over nRoute? (I really have no idea, as I'm never checked out iGuidance before.)
Old 05-07-2006, 10:16 AM   #11
Version 2.0 of Franson GPSGate has been released.
Says it supports Garmin USB to NMEA conversion.
Has anyone tried using 2.0 to get Garmin USB working with IG?
jayearl is offline   Reply With Quote
Old 05-07-2006, 02:40 PM   #12
Keep in mind, it's a beta. Not the final release. I'll be trying it out and I'll post if it works.
Old 05-07-2006, 10:36 PM   #13
-CM
It works
Beta 2.0 does work with iguidance, I'm using it now. Thanks for the tips.
Honda Ridgeline
Pentium M - 10.2" Screen
http://craigrmartin.googlepages.com
-CM is offline   Reply With Quote
Old 05-14-2006, 08:49 PM   #14
Work great for me since 2 week ! garmin 18 usb + IG 2.1.3
thx
SoWhat
SoWhatt is offline   Reply With Quote
Old 09-17-2006, 11:06 PM   #15
afterdigital's Avatar
funny, i currently had this same problem and google'd the issue. Well, the search pointed me to this discussion.
thanks Dylan, GPSGate worked! it programs my Garmin 18USB to have virtual COM ports allowing any navigation application to see it.
CTS 05, Mobile Information Center...
P4 - 2.8ghz
1GB Ram
320GB HD
8" TouchScreen
Digital FX
Finished Project
Car Hacking
WorkBlog
Video
afterdigital is offline   Reply With Quote
Question on Garmin 16 GPS receiver cproaudio GPS 19 05-23-2008 02:32 AM
garmin mapsource and usb gps mouse thecrow GPS 9 09-26-2006 03:24 PM
Delou Routis GPS USB install issues, please help... jedi7001 GPS 8 03-26-2005 11:29 AM
FS: USB GPS Mouse nappyjim Classified Archive 6 02-21-2005 10:48 PM
Garmin Serial USB=Fast, USB BU-303=Slow? ApacheXMD GPS 4 01-27-2005 04:49 AM
