Old 04-05-2006, 08:07 PM   #1
Registered User
Help buying 353/355 with iGuidance
Very confused... First it appears that I can't get a 355 as I'm using a laptop that has no PS2 port for powering. Can the packaged 355 with iGuidance sold here http://www.buygpsnow.com/iguidance-w...r-355-419.html work though? Does it come with a USB adapter? Can I buy the 353 packaged to save money?
Thanks!
infinitiqx4 is offline   Reply With Quote
Old 04-05-2006, 08:13 PM   #2
sfay93's Avatar
1st line under the hardware specs tab: Interface: Serial Interface
Last line: 5' long cable from GPS receiver to USB plug.
Looks like it is USB to me. Do you have a USB port on your laptop?
ATVMS.com
sfay93 is offline   Reply With Quote
Old 04-05-2006, 08:54 PM   #3
You can use a PS2 to USB adapter that comes with keyboards to power the BR-355.
bruha is offline   Reply With Quote
Old 04-05-2006, 09:03 PM   #4
Registered User
It is a dell 600m. Has 2x USB, 1 parallel, and 1 serial. I am using one USB for my touch screen. Sounds like the other will go to the GPS as I can't use serial connection w/o a PS2 to power. I also want to attach an external hard drive but those seem to require two USB for powering anyways, so I've pretty much given up on that one. I'm not sure how a PS2 to USB adapter for powering would help me any as I'd still be using USB!
Thanks for your help! I'm getting excited now that my screen arrived today.
Old 04-05-2006, 09:16 PM   #5
Fusion Brain Creator
USB hub ftw?
greenman100 is offline   Reply With Quote
Old 04-05-2006, 09:38 PM   #6
Registered User
Quote: Originally Posted by greenman100
USB hub ftw?
Not sure what FTW stands for. A USB hub requires a bit more for my setup as I believe I would need a powered one right... I currently have no inverter or power supply as the laptop uses a Dell DC-DC converter, the GPS powers itself through USB, and the LCD powers off 12V.
Right now I'm less worried about a USB hub for an external hard drive than hooking up a 353/355.
Old 04-05-2006, 10:24 PM   #7
Registered User
Aha, I think that buygpsnow is just not describing explicitly the package. Seems to be the same as what is sold directly from inav at http://store.yahoo.com/inavcorp-store/igsomorebu.html as the iGuidance bundled with 355 and a USB cord. So with this adapter I won't need any separate power connections huh? Sweet. Plus if I ever wanted to go serial I can with another cord. ;-)
Old 04-06-2006, 12:07 AM   #8
FTW = For the win
get a 5v regulator from radioshack, will cost about $2
Old 04-06-2006, 01:42 AM   #9
http://www.usglobalsat.com/item.asp?itemid=80&catid=
Is this a good deal? Is this site trustable? Thanks
itstdt is offline   Reply With Quote
Old 04-06-2006, 11:03 AM   #10
Registered User
I guess the question now is do I buy the 353 or the 355 w/ USB adapter? The 355 w/ adapter acts just the same as the 353 - ie all the data and power goes through a single USB cord?
Old 04-06-2006, 04:51 PM   #11
No, the 355 has a plug for serial + PS2. You use an adapter to go from PS2->USB, so you have serial + USB. The module gets power from the USB supply; the data still goes through the serial port.
Old 04-06-2006, 06:25 PM   #12
Registered User
Seriously? When I emailed buygpsnow they said it was explicitly just a single USB connection... Glad I asked here! Appears the 353 is just less of a headache to deal with and safer in case I get another laptop w/o serial.
Thanks!
Old 04-06-2006, 06:29 PM   #13
Thanks!
The 353 has a single USB, the 355 has a serial + PS2.
There are advantages to having serial over USB, serial avoids Windows hibernation issues, etc.
Old 04-06-2006, 07:11 PM   #14
Registered User
Yeah, I read about the hibernation issue. I think I read that using a USB hub would avoid the issue with the 353 though? Would that require always being powered or just accessory power before the laptop resumes from hibernation?
iGuidance SDK Quattro GPS 57 06-23-2006 07:37 AM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 12:46 AM
iGuidance Font Size Fix summary thread Viscouse GPS 29 03-28-2006 06:21 PM
Hacking Iguidance Peoples GPS 74 08-28-2005 06:40 PM
iguidance 2.1.1 - buying in the us. replicant GPS 2 08-03-2005 10:11 AM
