Old 04-07-2006, 11:09 AM   #1
qseven's Avatar
Smile Navigon nck 4.0 gps probs
Hi guys i ve just installed Navigon nck 4.0 with all europe maps and it works perfectly but it does not recognise my garmin bluethoot gps...it says no gps found.I made all settings with com port and i pair the antenna with my car pc before opening the program but nothing...probably it wants some particular antenna?????Mine works perfectly with any other nav software...any suggestion?Thanks from sunny italy
qseven is offline   Reply With Quote
Advertisement Sponsored links
Old 04-12-2006, 07:37 PM   #2
redbullah's Avatar
try to change the com port
ibus error
GTA skin
redbullah is offline   Reply With Quote
Old 04-13-2006, 07:48 AM   #3
qseven's Avatar
tryed but nothing to do!!!I ve also downloaded sirf test to check my antenna setting and everything seems to be ok...This is my spgps file:
[Default GPS]
GPS=GGA_VTG
GPS1=GGA_VTG
GPS2=RMC_GGA
[GGA_VTG]
Type=NMEA
Name=GPS with GGA and VTG messages
Device=SerialPort
Input1=GPGGA,utctime,latitude,ns,longitude,ew,qual ity,satellites,hdop,altitude,,,,,
Input2=GPVTG,course,,,,,,speed,
[RMC_GGA]
Type=NMEA
Name=GPS with RMC and GGA messages
Device=SerialPort
Input1=GPRMC,utctime,,latitude,ns,longitude,ew,spe ed,course,,,,,
Input2=GPGGA,,,,,,quality,satellites,hdop,altitude ,,,,,
speedMultiplier=1.851998
speedOffset=0.0
[SerialPort]
Port=8
Timeout=5
Baud Rate=4800
Byte size=8
Parity=N
StopBits=1
Binary mode, no EOF check=0
Enable parity checking=0
CTS output flow control=0
DSR output flow control=0
DTR flow control type=handshake
DSR sensitivity=0
Enable error replacement=0
Enable null stripping=0
RTS flow control=handshake
Abort reads/writes on error=0
XOFF continues Tx=0
XON/XOFF out flow control=0
XON/XOFF in flow control=0
Transmit XON threshold=0
Transmit XOFF threshold=0
Tx and Rx XON character=0
Tx and Rx XOFF character=0
Error replacement character=0
End of input character=0
Received event character=0
[SerialPort Detection]
PortCount=6
TestCount=0
Defaults=SerialPort
where is the error????thanks anybody
Old 04-13-2006, 09:50 AM   #4
redbullah's Avatar
indeed
i assume that it's a hardware error.
do you use the stock cable?
ibus error
GTA skin
Old 04-13-2006, 10:01 AM   #5
qseven's Avatar
first of all thanks for trying help me...I don t know what a stock cable is my gps is a garmin 10 bluethoot connected on serial port com 8 and it works perfectly with map monkey and mappoint on the same port...if you're using a bluethoot gps let me know your spgps file...many thanks
GPS not found in MapMonkey but is on GPSinfo.exe Ne-o GPS 4 07-19-2006 07:57 AM
CF 1.5 - GPS plug-in SOS CF Plugins 9 04-18-2006 03:28 PM
Cell Phone GPS EBFoxbat GPS 5 09-14-2005 07:45 AM
a new way of GPS brownpage GPS 8 08-24-2004 03:51 PM
Flashing A Sappire USB GPS - Probs With Destinator ccsnet GPS 0 09-07-2003 05:22 PM
