Old 04-15-2006, 06:46 PM   #1
Integrating multiple NMEA streams to one COM port
We have COM splitters for sending data from one GPS to multiple programs. What about the opposite? Two GPS units, located in different parts of the car, with a driver to sends their data to one port. Some decision making would have to be made as to which has the better data, but it doesnt seem like it would be bad at all. Any interest?
MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
Currently: Enjoying the setup, but always contemplating my next move...
rsd212 is offline   Reply With Quote
Old 04-16-2006, 05:09 AM   #2
DeltaFX's Avatar
If you use high precision gps, there is no need for more than one.
with low precision gps, theorically you could compute an average position, but they update their position when they want (you may have to wait .5 sec between gps A and gps B)... So you'll need to decode lat,lon,speed,heading, and more important, timestamp from each gps, add some serious maths, then recode output into a NMEA format......
If you're about to devellop a logic board to mix 2 lowcost gps units then you'd better have a look on "asynchronous / switched kalman filters" and build a high precision DR-proof board that would read your gps, a 2D accelerometer /gyrocompas and the speed signal from your car to output a highly reliable NMEA sentence.
Just my 0.02€
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
Old 04-16-2006, 05:33 AM   #3
nkotch's Avatar
Really no need for it so don't waste your time on it. There was a similar thread about using multiple antennas with a GPS unit so you could do a search for that and read some of the comments. For in car use spending the time and effort to build some sort of custome hardware/software to do that won't get you much (in my opinion) and it's possible it may not even work the way you're thinking it would.
Nick
'99 Ford Escort ZX2 CarPC <-- RIP Feb '07
2006 Chevy Equinox LS (Current Project)
**VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
nkotch is offline   Reply With Quote
USB port power dies?! pixelflash General Hardware Discussion 1 10-22-2007 10:26 AM
SDK commands over the serial port ???? tolisn Road Runner 4 12-14-2005 01:03 PM
Need help setting port number in the widcomm 4 driver malkalm PhoneControl 4 07-04-2005 05:38 AM
USB Serial Port Adapter Troubles bLindmOnkey General MP3Car Discussion 0 10-14-2004 12:29 AM
Via Mini-ITX Epia 5000 serial port not working vash General Hardware Discussion 2 08-13-2002 09:48 PM
