Quote:
4-6 datellites is normal, yes. Sometimes I get 7-8 if I'm out in the middle of nowhere with no buildings or anything around.
You don't need to run autoscan. The GPS will pick up the satellites on its own. Granted, you're not hurting anything by running the autoscan, either. Yes, the cursor will rotate. Your'e stationary, so the software has no way to determine a heading.
If your GPS is off, I can't help you. I'd contact the vendor and/or manufacturer for help with that.
The GPS is on so im guessing it just takes a while to start up.
Quote: Originally Posted by Jahntassa
Also iGuidance only updates once a second (or less) so it's not going to be to-the-foot accurate while driving. It's 'good enough' to figure out where you are and what direction you need to go in
Yea I don't have a big problem with it, I was just a bit concerned, I wasnt sure if this is regular behavior.
Quote:
If your GPS receiver has been turned off for more then 4 hours it will indeed require a longer period to start. Cold start usually takes about 45 seconds.
I see, I will time it and see what happens, it seems to take more than 45 sometimes.
Thanks for all the help everyone, appreciate it!
