Old 04-20-2006, 09:47 AM   #1
New GPS module is sensitive enough to be used indoors
Very interesting new product for our application. Hopefully this will be out in a couple months when I do a new build.
http://www.tgdaily.com/2006/04/19/navman_gps_jupiter30/
shollz43 is offline   Reply With Quote
Old 04-20-2006, 10:34 AM   #2
Marvin Hlavac's Avatar
Based on the specifications revealed in the article: "Capable of detecting signals as weak as -159 dBM", and "It can track up to 20 GPS satellites simultaneously" it appears the module will be based on the not-so-new-anymore SiRFstarIII chipset.
Marvin Hlavac is offline   Reply With Quote
Old 04-20-2006, 10:57 AM   #3
MySQL Error
jcdillin's Avatar
http://www.sparkfun.com/commerce/pro...roducts_id=466
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 04-25-2006, 04:09 AM   #4
Banned
RPM_VR4's Avatar
Yep, SiRF-III works well inside the house. It doesn't work so well inside a metal car though.
Does anyone know of a USB SiRF-III reciever that has an antenna connector? I have a BT one, but it turns itself off all the time and you have to press the power button to get it on again (even when charging from USB). I found a CF one with connector that I will probably use, but USB would be better.
I'd also love to see a SiRF-III with DR.
RPM_VR4 is offline   Reply With Quote
Ublox Dead Reckoning GPS jcdillin GPS 126 12-29-2007 04:25 AM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
OEM GPS Modules. IntellaWorks Hardware Development 91 03-08-2005 07:29 AM
Newbie's guide EBFoxbat Newbie 6 02-08-2005 11:06 AM
Window Tint's effect on GPS signal MoFo GPS 3 07-19-2004 06:08 PM
