Old 12-23-2006, 07:07 PM   #61
Marvin Hlavac's Avatar
If you want I can put together a quick exe file that will start Streets & Trips 2007 for you with some of the GPS functions enabled. Which functions exactly do you want to have enabled?
Marvin Hlavac is offline   Reply With Quote
Old 12-23-2006, 07:17 PM   #62
Thanks that would be great. I want it to start GPS tracking, Provide driving guidance, Arrange map view (rotate map view to follow travel direction). I usually have to check these each time I use S&T 2007.
Another question, I am using a 7inch screen and for some reason when i click the S&T2007 i cant use the Full screen view and i cant see the end of the screen like the routing option, etccc. I played with the Windows setting and made it smaller but still the screen seems too small.
Any suggestion or input with that. I just got RR downloaded on my laptop will fool with it before i migrate it into my Car PC..
Thanks again for the support
Ramez
ramez75 is offline   Reply With Quote
Old 12-24-2006, 08:11 PM   #63
The following was designed for Streets & Trips 2007 (It will likely not work with other versions)
Here's the code:
Code:
Opt("WinTitleMatchMode", 2) ShellExecute("Streets.exe", "", "", "", @SW_MAXIMIZE) WinWaitActive("- Microsoft Streets & Trips", "", 30) Sleep(1000) If Not WinExists("- Microsoft Streets & Trips", "Configure GPS...") Then send("!tp") WinWaitActive("- Microsoft Streets & Trips", "Configure GPS...", 10) ControlCommand("- Microsoft Streets & Trips","Configure GPS...","Button48","UnCheck","") ControlCommand("- Microsoft Streets & Trips","Configure GPS...","Button47","Check","") ControlCommand("- Microsoft Streets & Trips","Configure GPS...","Button49","Check","") ControlCommand("- Microsoft Streets & Trips","Configure GPS...","Button50","Check","") ControlCommand("- Microsoft Streets & Trips","Configure GPS...","Button52","Check","") ControlCommand("- Microsoft Streets & Trips","Configure GPS...","Button48","Check","")
And the compiled STstart.exe can be downloaded here »
Enjoy!
Old 12-24-2006, 08:27 PM   #64
Thanx Marvin Hlavac, i will try it tomorrow. Appreciate it
Ramez
Old 12-25-2006, 05:07 PM   #65
Enjoy!
Just got done installing S&T '07 and tested the exe. Works as it supposed to. "Safety Warning" window is still prompting however. What needs to be added in order to "stop" the prompt?
Jay_1.8t is offline   Reply With Quote
Old 12-25-2006, 05:16 PM   #66
Jay_1.8t how did u get it to work, I put the .exe in my startup folder but I got an error once i clicked on it how did u get around it to make it work.
Thankx
Old 12-25-2006, 05:19 PM   #67
Thankx
I didn't have to do anything, it just works. Sorry I can't be more helpful
Old 12-25-2006, 05:20 PM   #68
where did u put the .exe file
Old 12-25-2006, 06:28 PM   #69
It shouldn't matter where you run it from. Mine was sitting on the desktop.
Old 12-25-2006, 06:56 PM   #70
yes it worked i put it on the desktop and when i restarted the PC i ran it and it worked. But if I click on the S&T icon on my desktop then i have to configure it. What front end are u running. I guess the Startup.exe is gonna be the GPS PAth in RR.
@ Marvin Hlavac is there a way you can add the Safety Warning to be taken care off too.
I looked at the code and was wondering is the Safety Warning still Button 39 in S&T 2007 if not how can i know just for future.
So will something like that work, am I understanding the logic correctly. I use Fortran to program so I am presuming same if logic statement
if Not ControlCommand("- Microsoft Streets & Trips","Configure GPS...","Button39","UnCheck","") Then
ControlCommand("- Microsoft Streets & Trips","Configure GPS...","Button39","Check","")
EndIf
Thank you for your help
Ramez
Old 12-25-2006, 07:09 PM   #71
I'm on the latest release of RR. I played around with it a little and here's how I got rid of the warning window:
Just add this to the bottom of the code posted above
Code:
if WinWait("Safety Warning","") Then ControlClick("Safety Warning","",5912)
Old 12-25-2006, 07:24 PM   #72
hey guys i have been playing with this code from gameboy on the second page, here is what i am using now that works for me and microsoft streets and trips 2006.. first i decided to go a diffrent route and have the autoit program itself turn on streets click enable gps, center map, and rotate map. so there is only one click to run streets and trips with gps, and it does not run in a loop just one time and its done, if you would like to use this code just download autoit and compile this code place the exe in your streets and trips folder ( in program files) make a short cut to it, place short cut on desk top and just click the short cut to this script
Opt("WinTitleMatchMode",2)
Run("Streets.exe", "C:\Program Files\Microsoft Streets & Trips")
WinWait("Microsoft Streets & Trips","")
Sleep(5000)
if Not ControlCommand("Microsoft Streets & Trips","","Button39","IsChecked","") Then
ControlCommand("Microsoft Streets & Trips","","Button39","Check","")
EndIf
Sleep(3000)
if Not ControlCommand("Microsoft Streets & Trips","","Button41","IsChecked","") Then
ControlCommand("Microsoft Streets & Trips","","Button41","Check","")
EndIf
Sleep(1000)
if Not ControlCommand("Microsoft Streets & Trips","","Button44","IsChecked","") Then
ControlCommand("Microsoft Streets & Trips","","Button44","Check","")
EndIf
and thats it.. good luck
eagle_ems
eagle_ems is offline   Reply With Quote
Old 12-25-2006, 07:54 PM   #73
LEt me test this
Old 12-25-2006, 08:33 PM   #74
Jay 1.8T, I added the line to the above code and for some reason i got an error. Can u please send me the .exe u r using. I just wanna see what the hell is wrong with the one i am using Weird
ramez75@hotmail.com
Old 12-25-2006, 10:13 PM   #75
What error do you get and we are still talking about S&T '07 right?
Here's the file I'm using STstart.exe
CoPilot the only way to go for GPS! lbk GPS 17 02-19-2007 05:21 PM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
Newbie's guide EBFoxbat Newbie 6 02-08-2005 11:06 AM
Mediacar V1.8.5 coyote MediaCar 47 02-16-2004 02:16 PM
Making Winamp LCD plugin start automatically RobRoy General Hardware Discussion 1 11-06-1999 01:50 AM
