Old 12-25-2006, 09:15 PM   #76
Yes 07, i am getting an error from line 2 ShellExecute("Streets.exe", "", "", "", @SW_MAXIMIZE)
i will try urs
thankx
ramez75 is offline   Reply With Quote
Old 12-26-2006, 05:20 AM   #77
Marvin Hlavac's Avatar
Quote: Originally Posted by Jay_1.8t View Post
Just got done installing S&T '07 and tested the exe. Works as it supposed to. "Safety Warning" window is still prompting however. What needs to be added in order to "stop" the prompt?
1. I'm glad it works as designed
2. I don't have the right to remove a safety warning from someone else's product, though
Marvin Hlavac is offline   Reply With Quote
Old 12-26-2006, 05:26 AM   #78
That should not happen if you use the .exe I created. However, it is very likely you will get that error when you create your own .au3 or .exe from my code because that function is not yet supported by the newest version of AutoIt. Download AutoIt Beta.
Old 12-26-2006, 06:16 AM   #79
My bad, I meant to say activate "I agree" button on the warning window. I figured it out, thanks
Jay_1.8t is offline   Reply With Quote
Old 12-26-2006, 06:20 AM   #80
Old 12-26-2006, 09:55 AM   #81
Yours worked and once I downloaded the Beta version like MArvin Hlavac suggested my .exe worked too
Old 12-26-2006, 10:00 AM   #82
Window Size
A question i am using a 7" touch screen and i just wanted how all of you get around it, I dont get the whole MS S&T whether 2007 or 2006 window panel i only get upto configure GPS and nothing after that i cant even scroll the window down to get to the Routing section whereas on my laptop i have the whole window. I cant even use Full screen mode (F11) on my 7in screen.
Any suggestions guys
Old 03-17-2007, 05:06 PM   #83
BLAXKINNED's Avatar
Quote: Originally Posted by eagle_ems View Post
hey guys i have been playing with this code from gameboy on the second page, here is what i am using now that works for me and microsoft streets and trips 2006.. first i decided to go a diffrent route and have the autoit program itself turn on streets click enable gps, center map, and rotate map. so there is only one click to run streets and trips with gps, and it does not run in a loop just one time and its done, if you would like to use this code just download autoit and compile this code place the exe in your streets and trips folder ( in program files) make a short cut to it, place short cut on desk top and just click the short cut to this script
Opt("WinTitleMatchMode",2)
Run("Streets.exe", "C:\Program Files\Microsoft Streets & Trips")
WinWait("Microsoft Streets & Trips","")
Sleep(5000)
if Not ControlCommand("Microsoft Streets & Trips","","Button39","IsChecked","") Then
ControlCommand("Microsoft Streets & Trips","","Button39","Check","")
EndIf
Sleep(3000)
if Not ControlCommand("Microsoft Streets & Trips","","Button41","IsChecked","") Then
ControlCommand("Microsoft Streets & Trips","","Button41","Check","")
EndIf
Sleep(1000)
if Not ControlCommand("Microsoft Streets & Trips","","Button44","IsChecked","") Then
ControlCommand("Microsoft Streets & Trips","","Button44","Check","")
EndIf
and thats it.. good luck
eagle_ems
Excellent code..eases my stress..
BLAXKINNED is offline   Reply With Quote
Old 07-29-2007, 01:37 PM   #84
i have tried this in rr config to start this exe but it will not work. it works fine outside of rr. what am i doing wrong.
YellowMater is offline   Reply With Quote
Old 08-09-2007, 12:58 AM   #85
I've been working on getting S&T 2006 working and this was just the ticket! I don't really need anything except GPS location and moving map in the full window. If I need directions or a location, I'll pull over and get out the mouse and keyboard and manipulate the program.
Here's the AutoIT3 code I'm using with the RoadRunner MediaCar skin:
if Not ProcessExists("Streets.exe") Then
Else
WinActivate("Microsoft Streets & Trips")
EndIf
Sleep(2000)
Send("^a")
Sleep(1000)
ControlCommand("Microsoft Streets & Trips","Configure GPS...","Button39","Check","")
EndIf
Sleep(7000)
EndIf
Sleep(3000)
if Not ControlCommand("Microsoft Streets & Trips","","Button42","IsChecked","") Then
ControlCommand("Microsoft Streets & Trips","","Button42","Check","")
EndIf
Sleep(1000)
ControlCommand("Microsoft Streets & Trips","","Button8","Check","")
WinClose("GPS Sensor")
/END CODE
This checks to see if S&T is running and opens up it if it isn't. If it is already running, it moves it on top. It then opens the GPS tracking window, checks the boxes (with time delays to allow the GPS to initiate and sync), closes the GPS tab and the GPS Sensor window. It works REALLY well and allows the GPS to run in the background so it comes up instantly once loaded.
Here's a zip of the compiled .exe
Fenris_Ulf is offline   Reply With Quote
Old 08-05-2008, 02:17 AM   #86
blk02si's Avatar
Well I could not get any of the mappoint code in this thread to work, So I coded my own simple script which works great. Just click on it, it starts mappoint 06, launches GPS task pane, checks: track, center, rotate, then closes the GPS pane and leaves only the map, tracking your location. Enjoy!
Code:
Opt("WinTitleMatchMode",2) Run("C:\Program Files\Microsoft MapPoint\MapPoint.exe") WinWaitActive("Map - Microsoft MapPoint North America","") Sleep(300) Send("^a") ControlCommand("Map - Microsoft MapPoint North America","","Button39","Check","") Sleep(5000) ControlCommand("Map - Microsoft MapPoint North America","","Button41","Check","") Sleep(500) ControlCommand("Map - Microsoft MapPoint North America","","Button44","Check","") Sleep(300) ControlCommand("Map - Microsoft MapPoint North America","","Button8","Check","")
And here is the EXE compiled
My carPC - www.shocknet.us
blk02si is online now   Reply With Quote
Old 08-05-2008, 04:20 AM   #87
Nicely done!
This actually should no longer be an issue in the upcoming Microsoft Streets & Trips 2009, which is expected to be in stores in a few weeks (September 2008).
The above picture shows a new option that I now see in Microsoft MapPoint 2009. The same we should see in S&T 2009.
CoPilot the only way to go for GPS! lbk GPS 17 02-19-2007 04:21 PM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 05:54 AM
Newbie's guide EBFoxbat Newbie 6 02-08-2005 10:06 AM
Mediacar V1.8.5 coyote MediaCar 47 02-16-2004 01:16 PM
Making Winamp LCD plugin start automatically RobRoy General Hardware Discussion 1 11-06-1999 12:50 AM
