Old 04-21-2006, 10:09 PM   #1
Automatically start GPS for Streets '06
I've put together an AutoIT3 script to automatically start the GPS and answer the "safety warning" whenever it isn't already started. I searched before I did this and didn't see it anywhere, so I thought it might be useful to others:
Opt("WinTitleMatchMode",2)
While 1
WinWait("Microsoft Streets & Trips","")
if Not ControlCommand("Microsoft Streets & Trips","","Button39","IsChecked","") Then
ControlCommand("Microsoft Streets & Trips","","Button39","Check","")
WinWait("Safety Warning","")
ControlClick("Safety Warning","",5912)
EndIf
Sleep(5000)
WEnd
This can be compiled into an EXE file, and just run in the background. It checks once every 5 seconds and starts the GPS if necessary.
Zyll is offline   Reply With Quote
Old 04-21-2006, 10:18 PM   #2
Raw Wave
tj!2k4's Avatar
nice! thanks for sharing
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 04-22-2006, 01:09 AM   #3
Fusion Brain Creator
2k1Toaster's Avatar
I'm a complete moron with compiling exe's, but I would like this. How do I compile it? When I do then just run it and it will stay in the background processes and continuously check right? Any idea how much CPU power this uses? Thanks in advance.
Old 04-22-2006, 10:19 AM   #4
Just download and install AutoIT3, and save the script as a .au3 file. If you right click on the file, you will see an option to compile it to a .exe file (so that autoit doesn't have to be installed on the carpc). I think that the resources it uses are pretty minimal - it will just sit in the background and mostly sleep.
Old 04-25-2006, 07:51 PM   #5
2k1Toaster's Avatar
Thankyou. I just got around to compiling it. Works well. And to answer the memory ?, it takes 3.1Mb of RAM so basically nothing.
Old 05-15-2006, 05:51 PM   #6
I've been messing with this all day and its frustrating me to no end. I am trying to alter the script a bit so that it selects button39,41,44 and 45 (start GPS, rotate map, keep position centered, create gps trail) and I get some stupid error about no while command with wend. how am I supposed to add to this? I've tried everything! argh!
2005 Subaru Legacy GT, carputer in progress
Current status: Phase 1 Complete: working in car with no bugs, Phase II started, screen out of dash, making working mockup for beta testing
DarkFox1 is offline   Reply With Quote
Old 05-23-2006, 10:51 AM   #7
I used a line of sendkey button commands to do that...but I have to press a button. It went something like this.
B01,0,343,135,68,"ACTIVATE;Microsoft Streets & Trips||SENDKEY;%TGS%TGM%TGA","GPS On"
I'm not if sure you can execute a RR command upon loading a skin. I didn't get a chance to play with AutoIT3 yet. Sounds interesting.
Colossians 1:16 - Everything
vdog is offline   Reply With Quote
Old 05-23-2006, 12:45 PM   #8
breaker021's Avatar
I have not had the time to mess with this yet but do you think that this may be something that you can apply via registry?
For example, if u turnon the gps, the trailing function, and maybe some other functions, is there a change in the registry?
I am going to take a snapshot of my registry, turn on gps and some of the other options, then take another "after" snapshot of the registry... afterwards, i will compare the two "S&T" related hives and see if there are differences....
if this is the case, then you can create a batch file that does two things: launches streets and trips and immediately after launch, you can apply the .reg registry keys with a regedit /s (i believe) command...
i will let you know know next week how this works. my carputer is a mess right now. lol.
- sh00k
Duct tape and a Bandana for the win, b!shes!!!
My Setup:http://www.mp3car.com/vbulletin/show-off-your-project/73500-06-scion-xb-tablet-box.html
Cost so far: Less than a grand ;]
_________________
Economy/Commuter cars + Computers = many entertained miles
breaker021 is offline   Reply With Quote
Old 05-24-2006, 09:10 PM   #9
gameboy's Avatar
nice work(subscribed)
95 Mazda Protege LX
Worklog
Overall [Project Dead] 0%
2003 Nissan Altima
[XXXXXXXX--] 80% Planning
[XX--------] 20% FABRICATION/INSTALLATION
Worklog
gameboy is offline   Reply With Quote
Old 05-25-2006, 05:44 PM   #10
gameboy's Avatar
For Gps autostart, and rotate map, keep position Centered:
// Cut here
While 1
EndIf
Sleep(2500)
if Not ControlCommand("Microsoft Streets & Trips","","Button41", "IsChecked","") Then
ControlCommand("Microsoft Streets & Trips","","Button41","Check","")
EndIf
If Not ControlCommand("Microsoft Streets & Trips","","Button44", "IsChecked","") Then
ControlCommand("Microsoft Streets & Trips","","Button44","Check","")
Endif
Sleep(5000)
WEnd
//End Cut here
That will do it...., however you will not be able to turn that stuff off, with out closing the script, as ever 5 seconds it will check
95 Mazda Protege LX
Worklog
2003 Nissan Altima
Worklog
Old 05-27-2006, 08:01 PM   #11
Could you also have the script enable driving guidance from the GPS pane as well? Driving guidance=voice directions
Silentbob343 is offline   Reply With Quote
Old 05-28-2006, 10:24 PM   #12
gameboy's Avatar
ok here is what you need to do:
open s&t by itself, do not go thru front end,
open the driving guidance window, and make sure the gps window is open also,
add/remove any of the tooltrays you want/don't want
save as template to: program files\microsoft streets & trips\templates\
file name: New North Americian(should auto complete).
whenever you open streets and trips after that, it *should* open everything as you want it
95 Mazda Protege LX
Worklog
2003 Nissan Altima
Worklog
Old 05-29-2006, 12:58 AM   #13
The GPS pane has a couple boxes that can be checked and all of which are used in your AutoIT script:
"Start GPS Tracking"
"Provide Driving Guidance"
"Arrange Map View"
"-Keep Position Centered"
"-Use Dynamic Turn View"
"Rotate Map to Follow Direction"
"Create GPS Trail"
I'm familiar with the ability to save certain setting via template so why the need for a script? Specifically, if turning these options on and saving as a template will work to keep them turned on in future launches why the need for an AutoIT script? I can see using it to bypass the safety warning.
Old 05-29-2006, 03:52 AM   #14
"Arrange Map View"
"Create GPS Trail"
Saving as a template only saves what windows you have open (gps task pane, and the driving directions), and how many miles you have the map zoomed out to, but not the specific check boxes (keep position center, etc)
..at least that's how mine works.
Thanks for this script, I'm gunna have to test this one out. The popup warning and having to re-check the boxes each time is annoying.
Take 2 - '03 Audi A4
macmini with an 8" widescreen (in progress)
My 2004 Ford Ranger:
14" LCD w/ custom made aluminum bezel
Completly custom computer case
status: Totaled
Rocky388 is offline   Reply With Quote
Old 05-29-2006, 05:23 AM   #15
hmm......silly microsoft. They allow you to keep the driving directions checked when saved as a template, but none of the others....
As Rocky said, thank you for the script it's much appreciated.
CoPilot the only way to go for GPS! lbk GPS 17 02-19-2007 05:21 PM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
Newbie's guide EBFoxbat Newbie 6 02-08-2005 11:06 AM
Mediacar V1.8.5 coyote MediaCar 47 02-16-2004 02:16 PM
Making Winamp LCD plugin start automatically RobRoy General Hardware Discussion 1 11-06-1999 01:50 AM
