The MP3car.com Store
Thread Tools Display Modes
Old 04-28-2006, 01:01 PM   #1
01black_ac's Avatar
My Photos: (0)
Some Q's for anyone using a Rikaline 6010
I have a Rikaline 6010 USB version, and I've got some prelim questions, since I'm planning to start running all my wires in the next few days.
1. Do any of you experience problems with resuming from hibernate mode with the Rikaline always connected?
2. Have you mounted your's with a direct line-of-sight to the sky, or is it possible to mount it in the trunk under the rear shelf where the speakers are mounted? I've heard stories where people claim they have their Rikaline mounted under the driver or passenger seat and it has no problem acquiring satellites, but I'm not sure how true that can be.
I'm trying to figure out a good place to mount it in the car, and am thinking it will probably need to be somewhere near the rear of the car, possibly just snaked up from the trunk and onto the rear shelf or right under the headliner, where the headliner meets the rear window.
3. Is there any reason why a GPS unit should be mounted toward the front of the car (by the windshield) as opposed to the rear of the car? I had a problem powering the unit when I put it on the end of a 10' USB extension cable, so I'd like to keep it as close as possible to the computer in the trunk...
Basically, I'm just looking for some hints/insight as to best places to mount it. Does it absolutely have to have line-of sight to the sky?
'01
Hang on while I defragment my car...
the Acura ITX project
the Acura ITX skin for RoadRunner
project progress: 99%
01black_ac is offline   Reply With Quote
Sponsored Links
Old 04-28-2006, 01:12 PM   #2
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
I dont use hibernate so cant help there
Mine is located under the dash of my car, behind the instrument cluster.
Should be no problem with the extension, I have a 15 foot cable. However, I think mounting in the back is a good idea. One thing I did find was the GPS and LCD can interfere with each other. If my lilliput is running at 72Hz refresh rate, my 6010 sat number drops in half. So I keep the LCD at 60Hz and all is fine.
I would test it, again I do not need line of sight get 8-10 sats no problem, but only cutting through plastic then glass. Give it a test.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 04-28-2006, 01:33 PM   #3
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
I don't use hibernate, so no comment.
Mine is located on the front dash, behind the windshield. It will eventually be moved to under the scuttle panel in front of the windshield.
My PC is up front, so front of the car is closest for me. Generally the front screen of a car is more sloped, so putting the gps below this will give a view of more of the sky. If mounting at the back, perhaps consider mounting it outside on the roof, but take suitable waterproofing precautions.
'01
Line of sight will give you the best performance. I generally get between 8 and 10 satellites with it being on the dash at the very front. Move it back a few inches so it has less view of the sky, and the satellite locks drop off dramatically.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 04-28-2006, 02:07 PM   #4
01black_ac's Avatar
My Photos: (0)
Hmm.. ok... the thing about my Acura CL is that the rear window is almost the same slope as the front windshield, so I suppose if I mount it on top of the rear shelf, between the speakers, but at the bottom of the window, that might give me better reception. I'll probably have to test it in different locations, but the good thing about it being mounted in the rear of the car is that it won't require complete rewiring through the car just to reposition it, so rebuilding the inside of my car won't get held up by that (I'm so sick of driving around with most of my dashboard pulled out).
I would rather not mount it outside the car because that's just asking someone to come by and start pulling on it, but inside on the rear deck will probably work. I'll still have to figure out some way to mask it so it's not sitting out in the open.
Can these units receive if they're mounted upside-down? For example, if the magnetic side were facing up, would it still receive?
(I don't have the GPS hooked up to any test system right now, otherwise I wouldn't be asking these basic kind of questions)
Thanks for the help so far.
'01
Sponsored Links
vB code is On
Trackbacks are Off
No Sat Lock Inside Car With Rikaline 6010 Gps kyrenia GPS 8 05-08-2005 10:52 AM
Problems getting XP to recognize Rikaline 6010.. kingvitamin GPS 5 04-09-2005 05:37 PM
Rikaline 6010 Strange Fault clkraj GPS 0 01-22-2005 08:24 AM
My BU303 vs. Rikaline 6010 Review Nico3k The Review Palace 32 01-05-2005 11:42 AM
rikaline 6010 Locks up/reboots machine Lord_Pall GPS 4 12-30-2004 02:46 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
