Old 04-29-2006, 08:24 PM   #1
sama's Avatar
sama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud of
Anyone got TomTom running on a Palm device (not PocketPC)?
I'm trying to get TomTom going on a Palm OS Simulator and would like to know how the directory structure should be laid out for TomTom to work.
This will allow TomTom to be used on VIA based machines that can't use a PocketPC emulator.
If anyone has any experience with using Palm and TomTom together, please let me know how the files should be laid out and where.
Ta
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Old 05-01-2006, 06:39 AM   #2
Javiles is on a distinguished road
I have it running in pocketpc emulator
Hi, I have tomtom 5.1 running in mi carputer using de pocketpc emulator, but needs 97% cpu, I would like to try the palm emulator like you but I don,t found info about it.
Javiles is offline   Reply With Quote
Old 05-01-2006, 06:42 AM   #3
sama's Avatar
yeah, me too. you can set the priority of the process to low, giving other apps more precedence over tomtom.
I'm trying to get tomtom going using this: http://www.palmos.com/dev/tools/simulator/ but I keep getting some access violation and I don't know enough about the palm os to solve it (yet).
I was hoping that someone who has tomtom on a palm device could shed some light on that.
Old 05-05-2006, 08:34 AM   #4
Wolfsbane2k is on a distinguished road
Morning.
I'm using TomTom 5 (version 5.201 ) on a Palm T3, and have been using TomTom since v3 for 2+ years.
The idea of shifting TomTom to a Palm Simulator is very very interesting..
What do you need to know - I'm more than happy to help, especially if i can then use it in my new carpc
Wolfsbane2k
Fitting out a Skoda Octavia GLX.
Progress [__________] (ie nothing yet!)
Wolfsbane2k is offline   Reply With Quote
Old 05-05-2006, 09:04 AM   #5
sama's Avatar
fabulouls! an answer to my calls...
I install tomtom via the hotsync application and I can see the navigator to launch. But I'm not sure where tomtom looks to find it's map files etc.
where does tomtom expect them to be? memory card presumabely. in what folder?
cheers m8!
Old 05-05-2006, 09:20 AM   #6
I can't dump a printout of the TomTom card from here, but the jist is:
TomTom Programs are on the memory card root under:
\TomTom\
contains data.chk, munich.bin, data05.chk , data05.vif
The map folders are located under the memory card's root as well, for example
\Great_Britian_Plus-Map\
contains
CLINE.DAT
CNAME.DAT
CNODE.Dat
etc etc
These are the only two directorys on the normal Memory Card.
Any other maps are copied, folder name intact, to the route of the MC, which TomTom then picks up.
Good Luck!
Wolfsbane2k
Old 05-05-2006, 09:23 AM   #7
sama's Avatar
thanks. and what about locally on the device. how does tomtom install there?
I keep getting a very misinformatie error when I launch it and I'm sure it's down to incorrect naming. but I guess I'll see
Old 05-05-2006, 10:08 AM   #8
Hmm, i'm not sure about the location of the stuff on the internal memory - i haven't played with Palms SDK at all to work out how it all runs.
However, if you copy the software and maps from the CD to a memory card, then mount that in the Palm OS, it will automatically copy the required software over to the internal memory - and from there on, you can hotsync properly.
Old 05-05-2006, 10:25 AM   #9
sama's Avatar
fantastic. I'll give that a shot tonight
fingers crossed I can get this going. serial port mapping would be the next hurdle.
Old 05-05-2006, 04:14 PM   #10
Zip-Lock is on a distinguished road
I'm a big fan of the TomTom, after using the GO 300 on a recent trip. I'm just ordered the PocketPC version to play around with.
Zip-Lock is offline   Reply With Quote
Old 05-05-2006, 09:18 PM   #11
sama's Avatar
I've got a pocketpc version working with an emulator on the carputter, but it eats a lot or processing juice, which I would rather use for other stuff.
Im' currently trying to get it going with a palm emulator as they are less hungry.
Old 05-09-2006, 08:51 AM   #12
Have you got any further with this?
I hope so!
Old 05-09-2006, 09:12 AM   #13
sama's Avatar
hey, I haven't got round to trying it (contrary to my promise) as I'm waiting to get my TomTom CD back from my brother.
I've also been playing with iGUidance, which isn't too bad but doesn't compare.
will let u know.
Old 05-09-2006, 11:15 AM   #14
PURDooM's Avatar
PURDooM is on a distinguished road
It doesn't look as flashly but it has newer, better maps and the maps are more accurate. And it gets you going to where you need to go on a much more straightforward and logical route than tomtom.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 05-09-2006, 11:40 AM   #15
sama's Avatar
tomtom in the uk has pretty good maps, it also has a traffic service which when subscribed to, it reroutes based on traffic reports. it's saved my neck many times.
atop that, tomtom has some very decent camera detection plugins that use your vector + an angle to alert you of cameras more intelligently than other software. it also has full postcode lookup, and it's touch screen friendly out the box - without your plugin that is
How to remove Bluetooth wireless device support in Windows XP Service Pack 2 Player_One Wireless Communications 5 05-28-2006 05:52 AM
DirectSound device vs. Sound device BerkeleyTiger FrodoPlayer 0 03-29-2006 03:47 AM
Car PC + Palm = ?? Wolfsburged Newbie 1 04-11-2004 01:16 PM
Using a palm os device as controller babas151 General Hardware Discussion 13 05-17-2002 08:59 AM
