Old 04-30-2006, 07:38 PM   #1
bridqer's Avatar
What software has Multiple Stops Logistics Routing?
You know, the fastest order to do things in.
I use CarPC's in my trucks primarily for navigation, I cover three states and average 1000mi a week. I make 3-10 stops a day. I don't make any money while driving so it is important to me to spend the least amount of time driving.
I currently Use Copilot 9 for that reason. I can enter multiple stops, move my final destination to the bottom of the list, and select "optimize." It plots the fastest route from my current location, through all stops to my final destination. I like that I don't have to "plan" a trip, choose my start point, save the trip file, use it as my route.
Only the map data is sometimes inaccurate, might be a problem in all software, also I have been interested in trying some more frontend integrated nav software. So I am curious to know what other software would work for me.
I am pimarily interested in Iguidance and Streetdeck
The only other software I have used is Streetatlas+ 2003
'99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
MII12000opus120~MII12000opus120~MII10000opus150
NA~Senao dual 7.4 ant~Orinoco Gold
Pioneer~Pioneer~PG Octane-R R5.1MT
Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
bridqer is offline   Reply With Quote
Old 04-30-2006, 10:50 PM   #2
I use Microsoft Streets & Trips 2006 and it works pretty good for me. It seems to be doing what you need it to do as well. Put in all your stops, final destination and click on the plan my route button and it gives you 3 choices of traveling. I think they are like shortest, fastest, no highways? or something similar. If you put in how many miles per gallons your car gets, it'll even recommend when to pull over to pump gas as well!
aznprid972 is offline   Reply With Quote
Old 04-30-2006, 11:16 PM   #3
nkotch's Avatar
Just an FYI - iguidance won't do that. Currently use it in my car and I think that it'll only let you do one "stopover" in your route.
You could also look into the newest Delorme Street Atlas (2006 I think), I've got it installed on another computer so I'll have to take a look and see if it can do that.
One problem you may run into is that some nav programs that are designed to be easy to use in a car/integrated environment don't have all the fancy features that some of the other nav programs do that are a little more "involved" to use in a car environment.
Nick
'99 Ford Escort ZX2 CarPC <-- RIP Feb '07
2006 Chevy Equinox LS (Current Project)
**VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
nkotch is offline   Reply With Quote
Old 05-01-2006, 07:29 AM   #4
Neither darque nor pervert
DarquePervert's Avatar
CoPilot is/was one of the most sophisticated Nav programs around.
How do you do a 'stopover' in iGuidance? I haven't figured that one out yet...
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 05-01-2006, 10:48 AM   #5
MySQL Error
MatrixPC's Avatar
Once you have a route enter.
Menu->Destination->Stopover.
OP: MS S&T2006 does allow multiple stopovers. It's a very good trip planner software, but not a good nav software.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 05-05-2006, 08:05 AM   #6
bridqer's Avatar
Thanks all. I will just stick with copilot, it seems to do what I want best. I just wish I could synch the custom POI between my trucks. Copilot 9 now allows importing ov2 files, but has no way of exporting. Maybe next version.
Old 05-21-2006, 03:42 PM   #7
FLAC is for flaccid
parksgm's Avatar
Bridqer, it sounds like you've used CoPilot for a while...and I noticed that you've used Version 8 as well.
Did you notice any significant improvement in the quality of the map data between versions 8 and 9? What about POIs? I have version 8, and am frustrated by the lack of/missing POI information and sometime inaccurate map data.
Thanks,
Gregory
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Suggestion for the Software forum Confused Mp3car Forum Suggestions/Comments 11 11-02-2004 08:55 AM
myHTPC Software the_new_guy Software & Software Development 1 06-05-2004 04:51 PM
what routing software for Europe felix99 GPS 20 11-24-2002 09:52 AM
keypad software supporting multiple playlists minnow255 Software & Software Development 2 09-11-2000 03:46 PM
