The MP3car.com Store
Thread Tools Display Modes
Old 05-03-2006, 11:35 AM   #1
rsd212's CarPC Specs
Vehicle: 2005 Mazda3i
My Photos: (0)
Holux GM-210 vs GlobalSat BU-355: Head to Head Review
Motivation: I bought a GM210 off eBay as a low-cost solution for my GPS receiver. I needed USB at the time to work with my laptop. After months of frustration with reliability across two systems, I finally broke down and bought the BU-355 with Serial adapter.
Initial Impressions: The Holux was only $35. Its a bit ugly, but claims to use Sirf Star 3, so it seemed to be a bargain. The BU355 runs around $75 with the serial adapter. Its much slimmer, despite claiming the same capabilities.
Test Setup: Epia MII-12000. No extra peripherals, with Lilliput touchscreen being only present USB device. No other comm devices were used. Test was done on the dashboard of my Mazda3, with GPS units equidistant from the midline of the dash, approximately 3 inches apart, giving them the same view of the sky.
Cold Test: Both GPS units have remained unpowered overnight and have no idea where they are. I plugged in the receiver, started timing, and started iGuidance. After autodetect, I started recording the number of satellites reported to be locked.
Holux: After 1 minute, I had no locks. Two minutes, 1 lock. Finally after 8 minutes I had 3 locked satellites and enough for IGuidance to tell me my position.
GlobalSat: After 1 minute, I already had 4 locks. After 8 minutes I was locked to 5 satellites.
Driving Test: Driving around town, I simply switched back and forth between which antenna iGuidance was reading. Both remained powered throughout the test. Even though both antennas were located in the same place and were seeing the same sky, the GlobalSat BU355 held on to 5-7 satellites, while the Holux hit a maximum of 5, sometimes dropping back to 0 locks, but generally hovering around 3-4.
Final Impressions: The BU-355 ends up being almost twice the cost of the GM-210, but has proved to be far more reliable with much better reception. I highly recommend this unit.
MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
Currently: Enjoying the setup, but always contemplating my next move...
rsd212 is offline   Reply With Quote
Sponsored Links
Old 05-03-2006, 12:31 PM   #2
Queenambeach's Avatar
My Photos: (0)
Cool
I have the GM-210 and I get a lock in under 10 seconds no matter where I'm at! haven't had any problems as yet.
Queenambeach is offline   Reply With Quote
Old 05-03-2006, 02:52 PM   #3
My Photos: (0)
I dont disagree that there are GM210's out there working for people, but in my experience it has been a sub-par unit, always letting me down. Others also seem to complain about the GM-210. At this point, it seems like a crapshoot. Poor quality control, maybe?
Old 05-03-2006, 03:01 PM   #4
michael_16j's Avatar
Vehicle: 2002 BMW 325i hell ya
My Photos: (0)
I just bought a Holux 213 and have no problem with it, its small and fast, I plug it in start up i guidance and already have a lock and position and time, not bad for $57
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
I suggest get the better one the 213 is ten times better
michael_16j is offline   Reply With Quote
Old 05-03-2006, 03:20 PM   #5
Marvin Hlavac's Avatar
My Photos: (0)
No, that's incorrect. GM-210 is a fairly old receiver based on SiRFstar2 chipset. Nevertheless, it is a good performer, but I suspect neither of your two units were placed where they had good satellite signal (based on the low number of satellites you have reported). Try doing the same test again while both receivers are placed (at least temporarily) on the roof of the car. You will likely get at least 8 or 9 satellites on both receivers when in an open space (not among tall buildings, etc).
Marvin Hlavac is offline   Reply With Quote
Old 05-03-2006, 08:19 PM   #6
My Photos: (0)
Well, guess eBay can lie to you
I tried again today in a parking lot with both units on the roof (close to the passenger door, as thats all the cabling would allow). The GlobalSat picked up 8, while the Holux never picked up anything. At one point it had 2 locks, but those dropped out again. The Holux has done me well at certain times, but it just seems to fail when I need it most. You can argue the case that its just a bad unit, but for me, iGuidance doesnt lie
Old 05-04-2006, 07:37 AM   #7
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
EBay doesn't lie. The sellers on EBay lie.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
