Old 05-30-2006, 10:05 AM   #46
Bill-CZ's Avatar
THX man now it work, but i must often when i start emulator change serial port in Emulator, and don´t save...don´t have to some tip how to fix it?or don´t if it possible use only maps to destinator?
Bill-CZ is offline   Reply With Quote
Old 05-30-2006, 10:12 AM   #47
sama's Avatar
u should be able to use destinator no problem, but not tomtom with destinator maps.
there are ways of automating the serial port mapping externally. search for autohotkey
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Old 05-30-2006, 03:57 PM   #48
yellow99's Avatar
Hi Sama,
Got a question:
I got everything running but when the TomTom wizard pops up and i get to select the voice setting (after the clock setting) the whole PPC freezes up.
ive got the voices(dataXX.chk files) properly installed, do you (or someone else) have any idea what could be wrong?
yellow99 is offline   Reply With Quote
Old 05-30-2006, 07:50 PM   #49
sama's Avatar
yep, happened to me too. it's very annoying and you'll need to do the procedure again. only this time, dont' save the state until tomtom is started. I'm guessing you got hold of the image that somehow made it's way around
follow the tutorial to find the way, then save the state without the serial configured too
Old 06-02-2006, 11:58 AM   #50
Hi!
I'm able to start the emulator, everything is fine. When I start Tomtom the screen becomes blurry (almost unreadable). I can see that the Tomtom program is running (the setup phase).
What can that be?
claudioita is offline   Reply With Quote
Old 06-02-2006, 12:38 PM   #51
sama's Avatar
hi. the emulator screen or the computer screen?
Old 06-02-2006, 02:07 PM   #52
Bill-CZ's Avatar
Quote: Originally Posted by claudioita
Hi!
What can that be?
write me your resolution emulator?
when i change resolution and don´t was 640x480 or 800x600 it was unreadable.
Old 06-02-2006, 05:18 PM   #53
Just the emulator screen. I mean I can see well the emulator window (with the menu: file, flash, help).
The emulator screen is just fine when I start it, or when I exit the program Tomtom.
While the Tomtom program is running the screen is blurred, I can barely see what is written (the tomtom program setup process).
I also thought of a resolution problem, I tried 640x480x16 and 320x240x16, which other resolution shall I try?
Although I am not sure this is the problem since the emulator is fine with both resolutions, just the tomtom program not.
Old 06-02-2006, 05:32 PM   #54
sama's Avatar
tomtom will not work with non standard resolutions when the pocket pc will. for example, the pocketpc will run in widescreen mode but tomtom will appear completely unreadable. this is because tomtom's software writes in scan lines and will resize only at a 4:3 ratio (crap programming if you ask me)
claudioita, could you post some screenshots, and the exact settings your using to:
a) initially start the emulator
b) start the emulator thereafter
Old 06-03-2006, 03:39 AM   #55
"C:\Program Files\Microsoft\Device Emulator 2.0 Preview\DE.exe" "C:\Program Files\Microsoft Windows Mobile 5.0 MSFP Emulator Images\pocketpc.nb0" /s "C:\pocketpc.dess" /p /sharedfolder "C:\Storage Card" /vmname TomTom /video 640x480x16 /memsize 128
I tried also 320x240x16 and/or memsize 256
I renamed the program deviceemulator.exe in de.exe
You can see the tomtom is correctly running. If I press enter, it goes to ask the settings (also almost unreadable)
Old 06-03-2006, 05:13 AM   #56
sama's Avatar
very strange
try to delete this file C:\TomTom\Storage Card\Navigator\navigator.cfg
Old 06-26-2006, 05:37 PM   #57
fails to start with serials
Still nobody who have found a solution for this problem with the emulator not being abel to start up after state been saved when serialport for GPS connected?
I've got the emulator working fine on tomtom ver.5, but I cant make it go back to the state were com-ports has been setup.
vwp99 is offline   Reply With Quote
Old 06-26-2006, 08:04 PM   #58
sama's Avatar
if all else fails, it's not a very nice workaround, but you can use an external app like autohotkey to renable the serial ports on startup.
Old 06-27-2006, 04:38 AM   #59
redbullah's Avatar
i get pda working flawlessly on my homepc but tomtom cd doesn't want to install. I can't complain about it cause the cd isn't genuine (i want to try it out cause tomtom cd is more than 300€ with maps). Which version did you try exactly? I have here tomtom navigator 5.21. Cheers
ibus error
GTA skin
redbullah is offline   Reply With Quote
Old 06-27-2006, 04:46 AM   #60
Raw Wave
You can use the SDCARD version. You basically just copy all the files to the "Storage Card" and as soon as you boot up the PDA tomtom will install automatically on your PDA. If not just run the "autorun" file
Much much better than the CD version.
Chris31 is offline   Reply With Quote
ONINE PETITION: TomTom Navigator for PC bLindmOnkey GPS 19 06-07-2007 02:16 PM
Anyone got TomTom running on a Palm device (not PocketPC)? sama GPS 25 11-27-2006 01:28 PM
TOMTOM / Pocket PC Emulator / RR craignichollls Road Runner 107 08-25-2006 04:51 PM
PocketPC as a Touch Screen Replacement sama Other Cool Front Ends 59 08-05-2006 05:53 AM
