I need an alpha tester for a program I wrote. CommTest2 will track your position and velocity while driving. The attachments are photos.
CommTest2 Link at:
http://briefnotion.250free.com/
(Yes, it looks cheese. It is new)
Description and snapshots ------
Features:
Read NMEA data from com port or text file.
Altitude and Screen position based on travel speed, (allows you to look ahead)
Controls designed to be used while driving. Quick keys and voice audio allows you to navigate munus while you navigate your car. (sorry, couldn't resist the pun)
Customizable Menu system allows you make configure and call other apps.
Here is a set of instructions to get things stated:
Installation:
After installation find the install folder and copy "CommTestMenus" to a familure place. These files contain menu templates and sample templates. "CommTestMenus" will be your settings directory, so remember where you put the folder
Start the program, Click Control, With the control panel, click the file menu then click settings. Assign the field "Settings Directory" to the path of CommTestMenus. e.g. "C:\Documents and Settings\Ronald\My Documents\Personal Settings\CommTestMenus"
To load a test NMEA file, click the NMEA Text File rado button then the button with the period.
Make whatever adjustments you need.
Running the program:
Click Connect.
The button with the H will bring up a hot key help screen. Memorize then close.
Buttons 1, 2, and 3 will adjust the zoom level.
S - Screen Release on lets you navigate between other windows freely.
M - Will mute the voice.
The munu programs can be navigated with the cursor keys and enter key.
Load a KML path made by directions in GoogleEarth to get turn by turn audio.
