Script to Automatically press F3 when off course - Streets and Trips 2006
Hey,
Streets and Trips only reroutes your course when you press the f3 key. I have been working on a script that will:
1) launch streets and trips
2) wait 45 seconds until you've already entered your starting + end points and have already started driving
3) when the 40 seconds have expired, the script will automatically reroute every 40 seconds by sending the F3 keys.
just note - if you are running streets and trips 2006 with my script, then are using another front end or mp3 player or watching a movie, my script automatically brings streets and trips back up and presses the reroute button!
This is the script so far. THE SCRIPT IS NOT COMPLETE YET! I will tweak it this weekend when I have access to my car + gps reciever.
At least you guys can see what i've been working on:
Streets and Trips 2006.vbs
:: Script by sh00k for mp3car.com
:: May 31, 2006
:: This script fixes the annoying problem with microsoft streets and trips 2006
:: When you go offroute, you have to manually press the F3 key to have it recalculate the route.
:: This script does the following: 1) Launches Streets and trips, 2) Waits 45 seconds for you to
:: set your start and destination addresses and then once you are on your way, it presses the F3
:: (reroute) button every 40 seconds.
:: Problems with the script: no way to exit the script (without going to task manager), script is set to a finite (5,000) loop so hopefully this covers the legnth of your trip! ;]
:: Launch Streets and Trips 2006
Set WshShell = WScript.CreateObject("WScript.Shell")
WshShell.Run "c:\program files\microsoft streets & trips\streets.exe", 9
:: Waits 40 seconds until you have set your starting (optional) and destination addresses.
WScript.Sleep 5000
:: This is what will press the F3 key every 40 seconds.
for x = 1 to 5000
WScript.Sleep 10000
wshShell.AppActivate("Microsoft Streets & Trips")
wshShell.SendKeys "{F3}"
next x
__________________________________________________ ___________
If anyone can add to it or has comments before the weekend, great. it's a simple script that is very functional. you may even say it rocks your socks.
I am using a tablet laptop and it's annoying as **** to keep opening the onscreen keyboard and pressing the F3 button when i go off course. this way, it automatically reroutes itself. It aint the perfect solution but it's a solution regardless.
- sh00k
