Old 06-04-2006, 12:19 AM   #1
moeman_49 is on a distinguished road
iGuidance GPS Issue in RR
Hopefully this hasn't been covered before but I've searched for quite a while and haven't found anything. On to the problem.
I am trying to embed iGuidance into RR and when I try to open the program in RR it tells me that the GPS reciever can't be found. If I leave RR and open up iGuidance by itself, everything is fine and working. I have also embedded the app in Centrafuse and everything is fine when opening it there as well. I have tried iGMon and iGMod 4 as well and those dont' work either. If I open iGuidance with iGMon working and leave it open, then open RR, everything is fine. It seems that roadrunner is causing some sort of issue. Has anyone else had this problem? Thanks guys.
moeman_49 is offline   Reply With Quote
Old 06-04-2006, 12:23 AM   #2
b8bboi is on a distinguished road
open rr.ini and check if you have gpsport or mappointport set to the same port as iGuidance.
iGMon - Integration between iGuidance and Road Runner
CFX - Skin for Road Runner
b8bboi is offline   Reply With Quote
Old 06-04-2006, 12:34 AM   #3
ppgt94's Avatar
ppgt94
...and if it is, change it (in RR). The same GPS comport can't be used by two applications simultaneously. If you want give RR access to your GPS (eg. for heading direction and speed display) and use iGuidance you'll need a com port splitter like Xport.
ppgt94 is offline   Reply With Quote
Old 06-04-2006, 04:17 PM   #4
Thanks guys, that fixed it.
iguidance + rikaline 6010, gps "skips" fuctup GPS 3 07-03-2006 01:04 PM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 01:46 AM
RR and built-in GPS NRGZ28 Road Runner 6 04-17-2006 03:50 AM
IG, Works on it's on but not in RR (No GPS) tbird2340 Road Runner 5 03-11-2006 02:48 AM
how is iguidance compared to other gps software? emdzey01 GPS 3 05-25-2005 09:11 AM
