Old 06-04-2006, 01:41 PM   #1
unixxx's Avatar
unixxx is on a distinguished road
Smile OEM GPS Antenna
I've decided I'm going to buy the Garmin GPS 15L OEM receiver but need an antenna to pair with it. I want something semi permanent (ie not magnetic, adhesive maybe) with good reception. Are there better performing higher gain GPS antennas or are they all pretty much the same? I've heard people mention that the Gilssons are cheaper and have better reception than the Garmins but is this true or just a marketing gimick. Even among the Garmins there is great price gap, why are the Garmin GA 25 antennas so much cheaper than the Garmin GA 26 antennas? Much of my driving is on tree covered roads if that affects the antenna type at all. I notice the my handheld Garmin 48 which has a "stick" antenna gets twice as many satellites as my roof mount Raytheon 120 which has a flat pancake antenna. Just want to buy the right antenna the first time. Thanks.
# cd /home/fuzzymuzzle.com
Intel Pentium M Dothan 750 1.8GHz 533MHz 2MB
iBase MB896F w/ Intel 915GM
[■■■■■■■■■■■■■■■■■■■■] 50% Done
(Writing Front/Back End, Designing Electronics, and Completing Install)
unixxx is offline   Reply With Quote
Advertisement Sponsored links
Old 06-04-2006, 01:57 PM   #2
Change's Avatar
Change is on a distinguished road
If you get an active antenna, make sure you wire up the 15L so that you're giving a good clean 5v to the antenna bias line. I forgot that part and have to go back and add an LM7805. I'm using a Maxrad combination GPS antenna/NMO mount, it's designed to be active but it seems to work fine running passive.
The stick antenna is a quad helix, the flat pancake is a patch antenna. Patch has higher gain straight above, quad helix has higher gain towards the horizon. It looks like most vehicle antennas are patch antennas. See http://www.tessco.com/products/displ...h=false&page=1
System status: in progress
Change is offline   Reply With Quote
Old 06-04-2006, 02:50 PM   #3
unixxx's Avatar
Smile
The antenna's going to be more than three feet from the receiver so I think I'll go with an active antenna. Will a high gain GPS antenna be more directional and decrease my ability to receive certain satellites? Thanks.
Old 06-04-2006, 03:43 PM   #4
Change's Avatar
Hm. Not really sure how much the gain will affect your horizon reception. Here's a little bit of info, but it's light on details: http://www.gpsinformation.org/joe/gpsantennaspecs.htm
Old 06-04-2006, 04:04 PM   #5
unixxx's Avatar
Question
Thanks for the link, I've read in a few different places that helix is better for under the trees. I noticed that a lot of the patch antennas say they need a ground plane. Is placing the antenna on the roof of my car a sufficient ground plane or is something else needed?
Old 06-04-2006, 04:30 PM   #6
Change's Avatar
Roof/trunk lid are just fine as long as they're metal.
Old 06-05-2006, 11:54 AM   #7
unixxx's Avatar
Thumbs up
Ok, I just decided to go with the Garmin GA27C. It's the active antenna that's recommended by the receiver's datasheet. Thanks for the help.
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 65 10-13-2009 07:51 PM
Deluo GPS Diag and OEM GPS - Need Help edrex GPS 7 04-11-2005 09:35 PM
Solder cable of external antenna inside mouse GPS ?? swissRv GPS 11 12-06-2004 04:48 PM
Gps Module + External Antenna + Waas + Usb e_z_street GPS 3 10-06-2004 04:57 PM
USB DVD + Radio Tuner + OEM GPS gguy General Hardware Discussion 4 02-13-2001 12:43 PM
