06-06-2006, 06:43 PM
#16
Rear deck (hat shelf), works fine.
95 Volvo 850 T5 • Konis • ECU @ 17psi • 5+20% Tint • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • 2.5" BOSCH HID Projector Retrofit
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
06-06-2006, 06:45 PM
#17
Neither darque nor pervert
My BU353 sits on my dash presently. When I get down to the final install, it will be inside the dash under the plastic, sitting on the center console air vents. There's only one layer of plastic above the GPS, so I shouldn't have any problems getting a lock, nor any visible GPS for a thief to try to steal.
My Worklog
06-06-2006, 07:22 PM
#18
It would work with something in the way like that?
Ampie Case
2.5" Hard Drive 80GB Toshiba 5400rpm
Kingston 512 MB DDR RAM PC3200
Xenarc 700TSV - VGA Monitor
VIA EPIA M10000 Mini-ITX Mainboard
M1-ATX 90 Watt - Smart Power Supply
2005 Honda Civic
06-06-2006, 07:40 PM
#19
All GPS devices or antennas are enclosed in plastic... another layer won't hurt it.
06-06-2006, 07:50 PM
#20
Nice, I'll pick up the Holux, thanks. Continue to post though if anyone knows why I shouldn't.
Ampie Case
2005 Honda Civic
06-07-2006, 06:08 PM
#21
Meh,
I picked a sirf II gps up off ebay for 12 bucks.
Streets 2006 modified with reshacker and everything works perfectly. Sits on the package tray underneath the upholstry.
Our aircraft (I'm in search and rescue, 35 million dollar helo) has a 100,000 dollar gps system in it and only picks up 7 satellites, mine picks up 10.
Go figure.
cheers
BJ
06-08-2006, 12:43 PM
#22
sorry whats reshacker?
06-08-2006, 12:50 PM
#23
http://www.angusj.com/resourcehacker/
My Worklog
06-08-2006, 12:53 PM
#24
Quote: Originally Posted by DarquePervert
Damn beat me to it!
My Shadow used to look like this. She's better now!
06-08-2006, 05:15 PM
#25
right, read the detailing, but a bit confused what to use it for on S+T ? (might be me just being thick though!)
06-08-2006, 10:38 PM
#26
Just bought the Holux 213 for $85 Canadian! Should have it in a week. Now I need to figure out the software side. Anyone care to do a little spoonfeeding? I like Map Monkey but I heard mention of Destinator, why would I need 2 separate pieces of software? And does anyone know where I can get Canadian maps?
Ampie Case
2005 Honda Civic
06-08-2006, 11:50 PM
#27
I may be out of step in mentioning this here, but I figured better to do so than not.
UT-41, $35 from geeks.com... I got mine yesterday, it works great.
http://www.geeks.com/details.asp?inv...&cpc=SCH&srm=0
:: Mark
06-09-2006, 04:51 AM
#28
right, read the detailing, but a bit confused what to Use it for on S+T ? (might be me just being thick though!)
I used it to modify streets to a more touch screen freindly interface. Ie: bigger buttons, rearranged buttons, etc.
It's about the best coverage I've found for eastern canada too.
Cheers
BJ
06-09-2006, 05:48 AM
#29
No, man.
You've been ragged on in a number of threads.
I'll say it again.
Check the FAQ Emporium. There happens the be a FAQ to the FAQs or something similar there. There are a number of links to highly informative posts about GPS and software. There is one thread that gives user reviews of different GPS software packages with their pros & cons.
Consider me a librarian and I'm pointing you to the card catalog...
My Worklog
06-09-2006, 12:38 PM
#30
I've searched it. I'll look again though.
Ampie Case
2005 Honda Civic
| Thread Tools |
| Display Modes |
Linear Mode
