06-22-2006, 03:49 PM
#121
Calm Down Or Get A 2 Week Vacation -Love The Forum Policeman
Quote: Originally Posted by Cheekz185
how did you get rid of the No warning with V3 in RR?
With the NoWarning switch.
In RR Config, under GPS, enter the following exactly as it appears here
c:\program Files\Inav\Iguidance\iGuidanceUMPC.exe|nowarning
Done. Just so you know that is a "pipe" before no warning.
Michael
P.S. Works with other versions of IG as well.
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
06-22-2006, 03:57 PM
#122
Raw Wave
There are numerous (even dedicated) threads dealing with the removal of warning dialog. Not bein an idiot, just letting you know it has been discussed, addressed, and that there are several solutions! Good luck.
06-23-2006, 12:31 AM
#123
ok so i ordered from inav on the 16th. i havent heard anything about shipping or whatnot. wtf. any one else order from inav directly?
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
06-23-2006, 10:32 AM
#124
I got no confirmation Email...but it turned up by fedex yesterday. It doesn't work properly with Vista though. You have to set it not only to XP compatibility mode but also to foced 640x480 screen resolution wih all the destop features turned off.
So, with IG not working, Nortel VPN s/w not working and TiVo Desktop not working I think I'm going to remove Vista for now & go back to XP.
06-23-2006, 11:01 AM
#125
Have you tried iG 2.1.3 on Vista? Was it working?
06-23-2006, 03:15 PM
#126
O.K.
I played with it a little last night.
Like I said before, the menu is vastly improved. I have only played with it on the laptop so far, so it will have to wait till I can play with it on the Lilli and the TS.
Here is a short video from last night.
http://www.speedoptions.com/mike/ig1.avi
You probably notice what I noticed. Look at the left of the screen. The names are jumping all over the place. Makes it difficult to read something, or find a side street, or a street over from where you are driving. of course, this problem is amplified at highway speed.
I had a very similar problem with V2.1 when I added CTheme with a high font number. I remember that Marvin thought that V3 might have the ability to use a theme.ini file. So, I got out my old theme file, and went to put it in the IG folder, and look what I found,
Yeap, it ALREADY has a THEME.INI file. Hmmm, is that all the UMPC version is, aside from the change in the hardcoded Menu stuff (I will take ResHack to it when I get a chance and see if I can find the new/differences, but that is later). I opened up the theme.ini and lo and behold, the first setting is for Font size. They have it set at 18 across the board. So I set off and changed it to 12, and this is what it looked like
Better, but not perfect, and now it is harder to see.
I wonder if there is some way to "pin" the street names where they are. If Ic an't see it, and I need to, I can/will just pan the screen, but now, the jumping is just annoying.
On a side note, I think that IGMon can be used with V3 for screen switching and turn announcements. The Routing screen is very similar to before. Perhaps I need to speak with BB.
Let me know if you have any questions.
Michael
06-23-2006, 03:54 PM
#127
I suspect your THEME.INI is there from your old iG 2.x instalation. Uninstalling iG will not remove all files and folders. And installation of a new version in my experience doesn't install THEME.INI ;-)
I'll look at the video files when I get home. I'm "mobile" now (pc via GPRS).
06-23-2006, 04:34 PM
#128
lol I always install Beta software on a second system.
06-23-2006, 04:41 PM
#129
Wiredwrx, Windows Media Player cannot play the files for some reason
06-23-2006, 04:54 PM
#130
I see dead kittens
I can't open them in any of my players. WMP, WMP classic, quicktime VLN player, etc.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
06-23-2006, 05:08 PM
#131
ok so i emailed canceling the order, no response. i call the only number i can find, they are out and their voicemail box is full.
they havent charged my card. im giong to order from someone else. this is ridiculus
Pictures
#132
yeah I ran a check through GSpot
Results:
Bad Chunk in Frame Data-found bad length value
CODEC is: S-Mpeg 4 version 2, MP42, but I believe the file being damaged is what is preventing it from playing for us.
06-23-2006, 05:59 PM
#133
Raw Wave
pssssssssssst!
You must have missed post #99
Quote: Originally Posted by tj!2k4
I sent an email to iNav, but it seems that they won't be available for a while
Quote:
Dear Customers:
iNav Corporation will be closed from 6/19-6/30/06 for corp sales meeting and internal operational maintenance with limited email support and no telephone support. We sincerely apologize for the inconvenience. We will resume business on 7/3/06.
Thank you.
iNav Corporation
06-23-2006, 06:33 PM
#134
Sorry, it works in winamp on my laptop.
If someone has access to a better "video maker" that is freeware or trial period, I will do it again.
Try and download it, and play it in winamp.
As for the theme, I never thought about that.
Let me delete the theme file and see what happens. But, I can confirm that theme.ini does work on this version.
So, I just got rid of the theme file, and while it does look different, it still moves the names around quite a bit. I would post a video, but no one can see it anyway
Michael
06-23-2006, 06:34 PM
#135
Raw Wave
INI file is not automatically installed on v 3.
INI file works with v3 if manually created/added.
| Thread Tools |
| Display Modes |
Linear Mode
