Old 06-11-2006, 08:57 PM   #1
rvk2's Avatar
rvk2 is on a distinguished road
Extracting GPS coordinates
Hi everyone,
My team recently ordered a BU-303 GPS unit for a class project. Is there a way to extract the GPS coordinates in Windows? We want to extract the coordinates, save it in a text file and send it to a server.
~~~ReBeCCa~~~~
rvk2 is offline   Reply With Quote
Old 06-11-2006, 09:25 PM   #2
DJiK's Avatar
DJiK will become famous soon enough
Yeah, use Hyper Terminal at first.
[+R, "hypertrm", OK]
Set up the correct port, baud rate, etc.
Since it's constantly updating, you'd eventually want to write a program that reads it line by line and saves to a TXT file after a certain number of lines or seconds.
If you just need a one time example, save/export the text from Hyperterminal to a TXT file and use that for your project.
The sting that you're looking to parse begins with $GPRMC.
And this is what it means:
Code:
$GPRMC Recommended minimum specific GPS/Transit data eg1. $GPRMC,081836,A,3751.65,S,14507.36,E,000.0,360.0,130998,011.3,E*62 eg2. $GPRMC,225446,A,4916.45,N,12311.12,W,000.5,054.7,191194,020.3,E*68 225446 Time of fix 22:54:46 UTC A Navigation receiver warning A = Valid position, V = Warning 4916.45,N Latitude 49 deg. 16.45 min. North 12311.12,W Longitude 123 deg. 11.12 min. West 000.5 Speed over ground, Knots 054.7 Course Made Good, degrees true 191194 UTC Date of fix, 19 November 1994 020.3,E Magnetic variation, 20.3 deg. East *68 mandatory checksum eg3. $GPRMC,220516,A,5133.82,N,00042.24,W,173.8,231.8,130694,004.2,W*70 1 2 3 4 5 6 7 8 9 10 11 12 1 220516 Time Stamp 2 A validity - A-ok, V-invalid 3 5133.82 current Latitude 4 N North/South 5 00042.24 current Longitude 6 W East/West 7 173.8 Speed in knots 8 231.8 True course 9 130694 Date Stamp 10 004.2 Variation 11 W East/West 12 *70 checksum eg4. for NMEA 0183 version 3.00 active the Mode indicator field is added $GPRMC,hhmmss.ss,A,llll.ll,a,yyyyy.yy,a,x.x,x.x,ddmmyy,x.x,a,m*hh Field # 1 = UTC time of fix 2 = Data status (A=Valid position, V=navigation receiver warning) 3 = Latitude of fix 4 = N or S of longitude 5 = Longitude of fix 6 = E or W of longitude 7 = Speed over ground in knots 8 = Track made good in degrees True 9 = UTC date of fix 10 = Magnetic variation degrees (Easterly var. subtracts from true course) 11 = E or W of magnetic variation 12 = Mode indicator, (A=Autonomous, D=Differential, E=Estimated, N=Data not valid) 13 = Checksum
--Courtesy of http://www.werple.net.au/~gnb/gps/nmea.html
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline   Reply With Quote
Old 06-12-2006, 01:03 PM   #3
rvk2's Avatar
Thank you so much...that was just what I was looking for.
~~~ReBeCCa~~~~
Old 10-24-2006, 08:06 PM   #4
dejacky is an unknown quantity at this point
Question
forgive me for this newbie question. But does this mean the BU-353 and BU-303 can both calculate magnetic variation?
dejacky is offline   Reply With Quote
Old 10-24-2006, 09:28 PM   #5
Dragonknell911's Avatar
Dragonknell911 is on a distinguished road
Well not exactly sure if this is what you are looking for, but it came to mind:
http://msdn.microsoft.com/coding4fun...i/default.aspx
REBUILDING!!
Dragonknell911 is offline   Reply With Quote
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
My GPS scenario & Bluetooth quest. gizak GPS 13 04-12-2005 01:11 PM
Delou Routis GPS USB install issues, please help... jedi7001 GPS 8 03-26-2005 11:29 AM
few gps questions fuctup GPS 2 03-02-2005 02:40 AM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 02:34 AM
