Old 06-27-2006, 10:37 AM   #16
It's supposed to look like this.
But it looks like this.
Ampie Case
2.5" Hard Drive 80GB Toshiba 5400rpm
Kingston 512 MB DDR RAM PC3200
Xenarc 700TSV - VGA Monitor
VIA EPIA M10000 Mini-ITX Mainboard
M1-ATX 90 Watt - Smart Power Supply
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 06-29-2006, 02:44 AM   #17
SMKFree
liquid_smoke's Avatar
even though this is the gps section, this is prob not the best place to post this. Your problem isnt really with gps, its with the skin, RR, and embeding apps and whatever launcher you are using for IG.
I havnt tried this skin, but i bet MatrixPC is right in that, that 4arrows button goes to fullscreen or some other secondary gps screen. My skin does the same thing and when you do this there are certain things that have to be done for it to work correctly, but this is mostly on the skinners plate.
First thing, you are going to have embeding issues with IG if you do not have your gps device connected. In all of your screenshots it shows you dont have a gps lock/no signal and warning in first screenshot. This will give you embeding issues with skinbedder (llikely others) but will work fine when in the car. If you DO have a gps device on the same machine you took those screen shots from, then you should first fix this problem as IG should not show that message if you do have a device connected.
Things to check,
window name to use in RRConfig.exe
window name to use in ExecTBL.ini found inside the skins folder, you will likely see other gps options in this file
check your paths
also check the skin authors threads/read me's etc as im sure there is some setup info on how to configure things with this skin.
if all else fails go back to square one
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
[Release] SKINbedder v2 0l33l SkinBedder 242 07-05-2005 04:01 AM
DWW-700M/MTS12000 Motorized In Dash LCD Problems techy101 LCD/Display 17 06-29-2005 07:12 PM
New iGuidance vs. old Routis Marvin Hlavac GPS 0 05-18-2005 07:20 PM
anybody ever have problems w/ iGuidance crashing? silencery GPS 2 01-28-2005 07:45 PM
anyone having problems using iguidance and media engine? dannn GPS 0 08-01-2004 11:33 PM
