06-24-2006, 12:27 PM
#1
Problems with iGuidance, skinbedder, IGMON, RoadRunner
I'm trying to figure this out as I go and after a day of reading and testing, I think it's time to ask some questions. I have Road Runner working perfect and iGuidance working perfect. For some reason I'm unable to put the two together. I ran IGMON, both beta and non beta, with both iGuidance and IGLAUNCH, but still can't get it. So here we go.
I open RoadRunner and get this.
Then I click OK and get this.
After lots of troubleshooting, I realized I could right click RoadRunner on the task bar, minimize it, and I get this.
So I click the restore button to bring it up and get this.
And finally, when I restore RoadRunner, I get this.
So that's just part 1. Now we click the 4 arrows on the bottom of the navigation window and get this.
I click OK and it gives me this.
I click OK again and get this.
Now, I do have Windows set to open new browser windows as new instances but I don't think that would have anything to do with this. Or would it? Also, it appears to be changing songs everytime I click on something here, how is that?
Ampie Case
2.5" Hard Drive 80GB Toshiba 5400rpm
Kingston 512 MB DDR RAM PC3200
Xenarc 700TSV - VGA Monitor
VIA EPIA M10000 Mini-ITX Mainboard
M1-ATX 90 Watt - Smart Power Supply
2005 Honda Civic
06-24-2006, 12:41 PM
#2
I believe you problem is with the "Please make sure you have your GPS device COnnected" Try putting you GPS device in and have iguidance read its port upon load and then try it.... Second, dont use Igmon with iglaunch
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
06-24-2006, 12:43 PM
#3
Sorry, I don't get it. My GPS is always connected on port 3, how do I get iGuidance to read it upon load?
I already ran IGMON, is there a way to unrun it?
Ampie Case
2005 Honda Civic
06-24-2006, 12:52 PM
#4
In iGuidance go to "Tool" go down to GPS Options and then go to COM Port and then make sure that Com 3 is selected
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
#5
I think gpsgate has the ability to deliver dummy data to iGuidance while the real gps is loading. What you are seeing is a symptom of USB gps recievers comming out of hibernation.
06-24-2006, 01:39 PM
#6
It already is selected.
Ampie Case
2005 Honda Civic
06-26-2006, 01:32 AM
#7
Damn, I changed the Road Runner external GPS link from Skinbedder to IGLaunch, reinstalled iGuidance and pow!
But when I hit the 4 arrows, I'm still getting this ****. Why does it load iGuidance outside Road Runner? Even if I close Road Runner at this point, iGuidance stays open.
Also, the button sizes changed, how do I change them back? I saw a big button mod but I don't remember doing that. And I heard it doesn't work for iGuidance 2.1.3. I don't know, somehow I had bigger buttons.
Ampie Case
2005 Honda Civic
06-26-2006, 01:49 AM
#8
yeah I too had problems with getting IG to run in RR. I just gave up.....yeah I'm lazy and hoping that a better alternative will come along.
06-26-2006, 01:56 AM
#9
My Village Called
iGLaunch won't work if you don't have the GPS receiver hooked up. Here's a hint: run iG with the |nowarning.
06-26-2006, 10:19 AM
#10
The receiver is hooked up. And how do I run the |nowarning command?
Ampie Case
2005 Honda Civic
06-26-2006, 10:50 AM
#11
MySQL Error
open iguidance outside of everything else. Make sure you havea connection. Close it. Run it inside iglaunch. Should embed right (unless you need to change somethin in the .ini).
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
Developer of: RRFusion, MovieTimes, (new)RRMail, & RR Plugin Manager
Coming Soon:RRChrome, & CentraFusion
Is Your RR Plugin Managed?
06-26-2006, 11:26 AM
#12
Tried that. I tried closing it on its own exactly the way I want it to reopen inside Road Runner but no go. Only on the one screen, the external GPS screen is fubed.
Ampie Case
2005 Honda Civic
06-26-2006, 11:53 AM
#13
MySQL Error
Forget about iGlaunch, skinbedder.
Just run iG with RR. use iGMon if you like. It still have some bugs but the best iG enhancement so far. Also, I suggest you try JIT iG button enhancement.
about the nowarning parameter.
if you run C:\Path to iGuidance\iGuidance.exe, you will get the warning windows.
If you run C:\Path to iGuidance\iGuidance.exe nowarning, you don't get that warning windows.
With Roadrunner, you can't not run the command like above, but you have to run it like this C:\Path to iGuidance\iGuidance.exe |nowarning. The pipe (|) is the separator for the application's argument list.
06-26-2006, 07:34 PM
#14
So now I have the big buttons, thanks to MGD and his new iGuidance.exe file. And it loads fine in the NAVI window but still, as you can see above, I hit the 4 arrows and it loads the iGuidance outside Road Runner instead of inside.
I'm using the regular iGuidance.exe file to load, not the IGLaunch file, and I haven't ran any IGMON yet. Should I change any of this?
Ampie Case
2005 Honda Civic
06-27-2006, 10:44 AM
#15
MySQL Error
Do you know what that 4 arrow button mean?
Double check the skin for the command of that 4 arrows button.
I bet you that it mean full screen. And the command to run iG full screen is different from the GPS option for roadrunner.
| Thread Tools |
| Display Modes |
Linear Mode
