06-25-2006, 09:35 AM
#1
Vehicle: 2K1 Yukon XL Denali
Rikaline Help Please
So I've successfully used my Rikaline for a few years now but I just recently had to rebuild my CapPC. For some reason I can't get the GPS mouse to work now. I reinstalled XP Pro SP2 and the drivers from the CD and I even tried downloading the latest drivers from the web. When I run the auto detect from iGuidance, it finds it but then doesn't seem to receive any info from it.
Don't know what else to do. I've tried uninstalling and reinstalling, but for some reason it's just not happy. Does anyone else have any history with this particular problem?
Denali XL
Carputer yanked from the Jeep and installed in the Denali...pics coming!
Check the old one here
06-25-2006, 11:14 AM
#2
My guess would be that while you were rebuilding your CarPC the GPS receiver wasn't being used for extended period. Often times when we attempt to use a GPS receiver which was sitting idle for several weeks it may take even 30 minutes or longer for it to finally acquire lock on satellite signal. Once it has a good fix, all should be back to normal again, though ;-)
06-25-2006, 12:30 PM
#3
okie doke, I'll let it sit for awhile today and see what happens. Thanks.
Denali XL
06-25-2006, 03:05 PM
#4
...and make sure the receiver is outdoor and it has a good view of the sky in all directions when you are doind this.
06-25-2006, 06:55 PM
#5
Yeah, well, no bueno. I sat in the truck tonight for like an hour (thank God Howard Stern replays his show throughout the weekend) and it still didn't lock. Further more, when I tried to start the GPS via SA2006, it showed "NO GPS". I don't quite know what's going on with it. It worked great one day, then I had to reinstall windows and it hasn't worked since. I don't think that the unit has gone bad, it's definitely setting/driver related. The receiver blinks green but won't stay lit.
Denali XL
06-25-2006, 08:14 PM
#6
In many cases a blinking light indicates good satellite lock ;-) I'm not sure about your particular receiver, though. Others may give better feedback on this.
06-25-2006, 08:19 PM
#7
Vehicle: 2000 Protege
Under System Devices does the driver show up? Also try forcing the com port under iGudiance, sometimes the auto function does not do a good job, change the com port in iGudance to some bogus one, let it get the error, then switch to the proper com port, make sure speed is at 4800bps no higher.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
06-25-2006, 09:11 PM
#8
Marvin, it could very well be getting good signal, but all i know is that it's not getting to the software application.
Yeah, Zip, I tried that too, but I did move it to 9600bps, as I thought that was the recommended setting. I'll try it on the way to work tomorrow.
What should it show up as in Device Manager? USB2Ser?
Denali XL
06-26-2006, 07:26 AM
#9
Whelp, I moved the ports around and made sure it was set to 4800bps. I have a 45 minute drive to work and no lock.
Denali XL
06-26-2006, 08:26 PM
#10
Problem solved:
Turns out that I had to plug it into my USB hub that already had the wireless keyboard/mouse, and wireless adapter plugged into it (non powered). Crazy, I know. I swapped out all four ports on the mobo and none worked until I plugged it into the hub. Sometimes it found the mouse, sometimes it didn't, but it worked immediately when I added it to my USB hub.
Denali XL
06-27-2006, 03:23 PM
#11
Excellent!
Carputer
Sound Stage
| Thread Tools |
| Display Modes |
Linear Mode
