No, you should not notice any impact on your PCs performance. When tracking the software should use only a few % of the CPU. When initially acquiring satellites the software uses as much free CPU as is available but at a low priority so other applications will run with no impact. It runs fine on a 1GHZ machine so your 3000+ is way over the requirements.
