Old 07-23-2006, 04:42 PM   #1
iGuidance cant find BU-353?
Well now with CF 1.7 can finally run iGuidance 2.1 again...hooked up my gps reciever to one of the usb ports on the mobo(m10000) and tried scanning for it, manually entering the com port, installed the gps drivers...has this happened before to anyone? Could it be the usb drivers for the mobo?
m2x0p9x is offline   Reply With Quote
Old 07-23-2006, 04:55 PM   #2
Marvin Hlavac's Avatar
Have you installed the USB driver that came on the CD with your BU-353?
Marvin Hlavac is offline   Reply With Quote
Old 07-23-2006, 05:27 PM   #3
I couldnt find the cd..so i found Win_USB_Driver_Installer.exe on a website..PL something or other...is that the driver i need cause i installed it...Thanks for the quick reply..
Old 07-23-2006, 05:44 PM   #4
seanz0rz's Avatar
is it pluged into a hub? mine would NOT run off of a hub.
looks like you arent.
go into device manager, and under lpt and com ports, see if the usb serial bridge is there, and note the com port number, try manually clicking on that com port number in iguidance. also make sure your baud rates are correctly set. not sure the exact setup for mine as i just ripped mine out of the car for installation into my newer vechicle that should come in time.
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline   Reply With Quote
Old 07-23-2006, 06:01 PM   #5
Under the device manger i have an error with the (Universal Serial Bus) controller...i have an m10000...i was thinking that was because of the USB 2.0? Cant member if there were updated drivers for it...I have used the gps reciever on this computer with CF 1.4...havent changed anything so im puzzled..
Old 07-23-2006, 06:07 PM   #6
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Unless the MB or the GPS is now broken, it is not a hardware issue. 2.0 and 1.0 are backwards compatible, that should not be the problem.
Why did you install different drivers (the ones you found) if it was working before. Are you trying to setup IG while IN CF?
You must set up IG outside of CF. Start IG, set it up, then close it. When you close it, it AUTOMATICALLY saves the settings. Then try opening it in CF.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
Wiredwrx is offline   Reply With Quote
Old 07-23-2006, 06:15 PM   #7
I installed the drivers again because nothing else was working and i didnt see them in the installed programs...but ya i know ig is setup on its own and then only embedded to run...but ive had this problem before but it found it on the second scan...i will try to reinstall the via usb drivers and see whats up...any other ideas...
Old 07-23-2006, 06:30 PM   #8
Neither darque nor pervert
DarquePervert's Avatar
You need the Prolific Serial-to-USB adapter driver. If that's not what's installed, it's not the right driver.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 07-23-2006, 06:55 PM   #9
Alright got this mamma jamma working...all usb ports are working properly...got the reciever set up in IG...but now its not locking on to any sats? i can see the nmea strings passing through just wont lock on...and weather is clear today..
Old 07-23-2006, 08:24 PM   #10
just give it a bit of time... being outdoor always helps, too.
Old 07-23-2006, 08:49 PM   #11
Well outdoors is not that fun today...its 112 where i live right now...and no shade in sight..lol...ill wait till the evening...thanks...
iGuidance icon & button resizing summary thread Viscouse GPS 4 10-07-2005 08:41 PM
IGuidance Embed - Sound Files Missing or Corrupted Error kbreeden Centrafuse 3 08-23-2005 08:17 PM
iGuidance 2.x auto-run shortcut ziggyrama GPS 1 08-13-2005 07:05 PM
New iGuidance vs. old Routis Marvin Hlavac GPS 0 05-18-2005 08:20 PM
iGuidance or Rand McNally SouL-FoRTuNe GPS 5 05-04-2005 10:01 PM
