Old 07-25-2006, 08:55 AM   #1
antenna gps crazy?? help me..
I re-installed Navibe Gps Usb antenna but when i connect this antenna, pc told me "Ballpoint Microsoft serial installed" and cursor run up and down!! I tryed with notebook and it is same!!
Danielealleli is offline   Reply With Quote
Old 07-25-2006, 08:58 AM   #2
did the ant come with a driver CD? if so use that instead of what microsoft recognizes.
Giant_kyle is offline   Reply With Quote
Old 07-25-2006, 09:21 AM   #3
i use antenna's driver..
now i find this description and i try..
http://www.pocketgpsworld.com/fortuna-u2-gps.php
on half page spooke about it..
Old 07-25-2006, 09:37 AM   #4
red_parchel's Avatar
poss. remove the device, install the driver, then connect the ant. to a different usb port, and carefully select the correct driver, i have these kinds of issues w/ my usb bluetooth devices ALL the time, it may take a few reinstalls .. but make sure you install the drivers FIRST, then plug in the device ... hope that helps
Carputer Status:
MobileOne: Gentoo reinstall/optimization - coming soon!
MobileTwo: ubuntu quick fix while MobileOne's out of service
--worklog--GeekBlog--
Audio: stage 2 nearing completion
red_parchel is offline   Reply With Quote
Old 07-26-2006, 02:20 PM   #5
I fixed this issue with my GPS by just disableing the "Serial Mouse" device that windows installed.
parid is offline   Reply With Quote
Old 07-26-2006, 02:25 PM   #6
that'll work! glad to hear it
Carputer Status:
Old 07-27-2006, 07:06 PM   #7
Lol, I had the exact same problem. I just disabled the device then uninstalled it. It does pop back up if I keep connecting and disconnecting it, but that is unavoidable.
'98 Peugeot 306
Project Status: I sold it ages ago!
ShutControl
The ultimate shutdown control software for laptops.
Design is Black and Pink
www.sonassi.com
blessani is offline   Reply With Quote
OEM GPS Antenna unixxx GPS 6 06-05-2006 10:54 AM
holux 210 gps antenna problem Help please professorjason GPS 4 09-04-2005 12:38 PM
Solder cable of external antenna inside mouse GPS ?? swissRv GPS 11 12-06-2004 03:48 PM
GPS + FM antenna replacement... paperinics GPS 2 10-11-2004 01:08 PM
Gps Module + External Antenna + Waas + Usb e_z_street GPS 3 10-06-2004 03:57 PM
