Old 08-10-2006, 12:59 AM   #1
GPS for LCD?
Hi,
I picked up a 3.5 dash DVD playing radio for my jeep (mostly used for offroading). In my latest project with the jeep, I am in the process of adding 1-3 cameras (I have not figured it out yet) for under the jeep (then I can see what I am crashing into).
Thats neither here nor there related to my question. I bought this LCD which has a video input. I have a Garmin GPS V with software that I have been using for years. I would like to somehow hook up the GPS V to the LCD. Since I have not read about any GPS V to Video output cables, I am not sure if that can be done.
I dont mind using the GPS itself to input the information (destinations, etc), I would like the GPS data (maps, etc) to be viewed on the LCD screen, if it were a direct copy of everything on the GPS V screen, that would be fine too.
So, I have the LCD & the GPS, but is there some way to display the GPS data on the LCD, if not, what can I get that would do the trick?
Thanks,
Rich
RichTJ99 is offline   Reply With Quote
Old 08-10-2006, 01:04 AM   #2
There's no way to do a straight output of what you seen on the Garmin's screen to the LCD. The best you could hope for would be to use it's NMEA output to drive some GPS-enabled software on a laptop or similar.
"It's a blessing . . . and a curse."
Siezmik is offline   Reply With Quote
Old 08-10-2006, 01:55 AM   #3
I appreciate the response. I would like to use the 3.5" lcd screen in the dash due to it staying a bit more hidden. I have an older shuttle 933mhz pc that is sitting collecting dust. I am a little concerned that the rough offroading will kill the hard drive rather quickly.
Would I be able to see anything on a 3.5" screen (much larger than the garming but I wouldnt want to look at windows on it)?
I have a PC, the GPS, I guess I need an inverter & somewhere to store the pc? I even have a laptop I could use (an old beater), maybe that would be better than the desktop? Boy I would hate to have a flood in my jeep (its happened).
Old 08-10-2006, 09:15 AM   #4
Without knowing the specs of your LCD I'm just taking a stab in the dark, but here goes. Assuming there's no VGA input for the LCD, and assuming that the inputs are all composite video, then it's not worth the effort IMHO. Text will be unreadable and the maps will be fairly blurry. Of course, your Shuttle would need to have TV-out for this to even slightly work.
Old 08-10-2006, 09:30 AM   #5
red_parchel's Avatar
you could put your laptop in case, like one of the ones pelican makes, and pull the cable through a hole and seal the hole w/ your sealant of choice, if you're conserned about water damage. ... just a thought
Carputer Status:
MobileOne: Gentoo reinstall/optimization - coming soon!
MobileTwo: ubuntu quick fix while MobileOne's out of service
--worklog--GeekBlog--
Audio: stage 2 nearing completion
red_parchel is offline   Reply With Quote
Old 08-10-2006, 10:43 AM   #6
You could somehow do it, just filter the video out to the RCA cables of the LCD. But you wouldn't want to do this because the new LCD wouldn't work with any of the touchscreen abilities. Since you're not running the USB cable from the Garmin to the screen, it's not filtering out the touchscreen. You'll have to control it from the Garmin.
Ampie Case
2.5" Hard Drive 80GB Toshiba 5400rpm
Kingston 512 MB DDR RAM PC3200
Xenarc 700TSV - VGA Monitor
VIA EPIA M10000 Mini-ITX Mainboard
M1-ATX 90 Watt - Smart Power Supply
2005 Honda Civic
Maheriano is offline   Reply With Quote
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
Cell Phone GPS EBFoxbat GPS 5 09-14-2005 07:45 AM
Delou Routis GPS USB install issues, please help... jedi7001 GPS 8 03-26-2005 11:29 AM
few gps questions fuctup GPS 2 03-02-2005 02:40 AM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 02:34 AM
