Old 08-16-2006, 10:19 PM   #1
nkotch's Avatar
iGuidance not remembering com port
Couldn't find any other threads about this, but is there a way to have iGuidance remember what com port it was set to between restarts of the computer/program?
I run it embedded in RoadRunner (shouldn't matter anyway), but at times, each time I start iGuidance I have to go back into the Tools menu and reselect the correct GPS com port (13 in my case). It's just now a pain because I'm running it embedded in a skin that hides iGuidance's File Menu bar, and in order to select the GPS port I have to close iGuidance, minimize the skin, open iGuidance from the desktop by itself, select the port in from the File menu, close iguidance, go back to Road Runner, and then open GPS in the skin.
Just wondering if there was a way (hack, registry key, etc...) to tell iGuidance to always use a specific default GPS port.
Thanks,
Nick
Nick
'99 Ford Escort ZX2 CarPC <-- RIP Feb '07
2006 Chevy Equinox LS (Current Project)
**VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
nkotch is offline   Reply With Quote
Old 08-16-2006, 10:52 PM   #2
Change your com port to a number lower the 13! Change it to a number under 10...I had the same problem. GO to device management and under ports rightr click your GPS receiver and go to properties then click advanced! Change to a different port i garuntee thats ur problem!
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 08-17-2006, 10:32 PM   #3
nkotch's Avatar
Will have to try that. I'm just using a garmin serial gps unit and Xport to split it to several programs so I'll go play around the xport com assignments. Had crossed my mind to try this but I guess I thought it just shouldn't matter, why remember a single digit com and not a higher one?? *sigh*.... oh well.
Nick
Old 08-17-2006, 10:38 PM   #4
crez79's Avatar
The only was I could get iGuidance to remember the GPS port was to make it com1. I set up the GPS to be on com3 and use xport to make it com1 (for iGuidance), com5 for rr, com6 for mappoint (i think). Any how, that is how I got it to work for me.
Good luck.
Yeah google!
crez79 is offline   Reply With Quote
Old 08-18-2006, 05:20 PM   #5
I had the same problem but found this thread:
http://www.mp3car.com/vbulletin/gps/57800-small-iguidance-problem.html
where someone explained that the INAV's FAQ tells you how to change the com port manually. Just change HKLM\Software\iNav\iGuidance\CommPort
to the desired value using the registry editor of your choice.
2006 Subaru STI
Voom2PC with CN700 Lilliput 7" Digimoto mOByDic
Sirius-SR1 BU-355 - EWF/Roadrunner/LSX
saverio911 is offline   Reply With Quote
Mini-ITX boards RedGTiVR6 General Hardware Discussion 89 08-27-2008 04:05 PM
Iguidance COM Port issues! Cheekz185 GPS 9 03-27-2007 10:13 PM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 01:46 AM
iGuidance Font Size Fix summary thread Viscouse GPS 29 03-28-2006 07:21 PM
IGuidance support! No need for a port splitter. xBrady GPSSecure 17 09-01-2005 11:11 PM
