iG-v3 issues: Road edges / starts at 1000' / north indicator broken?
I installed ig v3 and have a few problems that I can't find addressed anywhere in the forums:
1. It always starts zoomed into the 1000' level no matter where it was when I last closed it down. V2 started off at the zoom level where you left it.
2. At zoom levels of 1000' and closer, the streets are not drawn with two colors (edge and fill). They just appear as a thick globby line (see attached screenshot).
3. The north indicator never changes no matter if I select north up or heading up. Although the actual map behaves properly according to the setting.
I've tried iG both with and without a theme.ini file but there's no difference. Any ideas????
Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
