The MP3car.com Store
Thread Tools Display Modes
Old 01-13-2007, 02:00 PM   #16
AngryMan's Avatar
Vehicle: 94 vw golf
My Photos: (0)
coiudl someone just make this into a patch exe to save some of us some work?
I assure you, I am NOT lazy, but I am spread so darned thin most of the time I hardly have time to eat, let alone run time consuming res hacks on applications like this. either way, I am glad someone found out how to add this feature to iguidance. I defenitely have had a need for coordinate entry more than a handful of times.
keep up the good work
p.s. thanks for the warning to stay away from 3.1
.______
/ '__|__\____ VW CarPC project
\(o)_____(o)/ Full Spead Ahead!
Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
www.summitadventuresystems.com
AngryMan is offline   Reply With Quote
Sponsored Links
Old 01-13-2007, 03:16 PM   #17
LiquidKernel's CarPC Specs
LiquidKernel's Avatar
Vehicle: 1995 Volvo 850 T5
My Photos: (0)
Amazing! Thank you for the credit, but I think I was just the first person to bring up the topic.. I didn't send the res file. So technically, someone else deserves the credit!
I am super glad this worked... time to mod!
95 Volvo 850 T5 • Konis • ECU @ 17psi • 5+20% Tint • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • 2.5" BOSCH HID Projector Retrofit
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
LiquidKernel is offline   Reply With Quote
Old 01-14-2007, 12:57 AM   #18
AngryMan's Avatar
Vehicle: 94 vw golf
My Photos: (0)
I would like to point out that it might be confusing for a noob to add this mod.
firstofall, if you are using the fullsized "laptop" version of iguidance, make sure you use the code in the second post.
secondly, you will need to import the 1092.res file from the zip, by opening reshacker, then in reshacker click file, open, and point to the iguidance.exe.
then click on dialog and click action on the tool bar, down at the bottom of this menu you will see "add new resource".
point to the 1.92.res file you downloaded from the zip.
once it is in there, you will need tochange the content to thestuff for the full sized iguidance. just navigate to the 192. dialog, open it up and close the box that pops up (if it is so big you cant see the X to close the box, just hit escape and it will go away) then select all the code in that box and delete it, then paste the code in from the second post on here.
im falling asleep as I type this, so I might not be making any sense...
.______
Old 04-20-2007, 09:08 AM   #19
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
I have sometime to play with 3.01 yesterday. This is what john1701 talking about regarding to dialog 1092
It's just suck.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 04-29-2007, 01:26 PM   #20
Raw Wave
lostreception's CarPC Specs
lostreception's Avatar
Vehicle: Chevy Van G20 and '06 Scion Xb
My Photos: (1)
It's just suck.
the mod can be done but must be done manually with 3.01 or someone needs to make a patcher of the 3.01 version the patcher is exe specific thats why i suspect this is the problem but i cant confirm as i don't have 3.01 and only 3.0 BTW is there any real benefit to 3.01?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Sponsored Links
Old 04-29-2007, 02:03 PM   #21
john1701's Avatar
Vehicle: 2001 Ford Crown Victoria
My Photos: (1)
It's just suck.
it still works with the gas plugin for coordinates to go to the gas station, you just cant put in the lat and lon manually.
CAR:2001 Ford Crown Victoria
PC: Dell 600 NoteBook with Vista
CPU:specs
Memory:1G
Drives:usb 250gig
WI-FI:Cingular
misc:inverter 300w
GPS:IG 4
Screen:Xenarc 700TSV
The Florida Meets Thread
Simple Fix to Road Runner and Vista
john1701 is offline   Reply With Quote
Old 04-30-2007, 08:41 AM   #22
MySQL Error
MatrixPC's Avatar
My Photos: (0)
Personally, I don't see any change between the 2 version.
If you haven't update yet, keep it at 3.0. If you already did, well, try to go back. That is what I'm going to do next. Well, prior to upgrade, I backup the exe so I just replace it back. No uninstall/install needed.
Old 04-30-2007, 10:36 AM   #23
john1701's Avatar
My Photos: (1)
i agree, there really isnt any diff or reason to go to ig3.1. just stick with 3.0.
CPU:specs
Memory:1G
Drives:usb 250gig
WI-FI:Cingular
misc:inverter 300w
GPS:IG 4
Old 07-03-2007, 06:40 AM   #24
Zip
Vehicle: 2004/Subaru/Wrx
My Photos: (0)
I might be missing something but wouldn't it be nice if that dialog box had a dash? Most coordinates I use require the dash. But other than that I've got to say this hack is awesome.
Epia M9000, Opus150w,
512mb, 120hd, Lilliput TS 7in, GPS mouse, IRMan/Pioneer Steering Remote,
RF keyboard/trackball
Zip is offline   Reply With Quote
Old 03-22-2008, 01:43 PM   #25
bambam's CarPC Specs
bambam's Avatar
Vehicle: 1995 Mitsubishi 3000GT SL
My Photos: (0)
Has anyone got an "updated" one for IG4? I tried the hack but the results look similiar to what you saw with v3.1
"Imagination is more important than knowledge." -AE
bambam is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Touchscreen starts off X-Y coordinates for first 10 minutes. judoGTI General Hardware Discussion 7 04-02-2005 09:24 PM
In the MP3 selection, I can use the forward button all the time, but not always back clean customs FP Bug Reports 4 03-23-2005 10:33 AM
How to get to back of headunit nick8197 Newbie 9 02-11-2005 11:55 AM
USB HD enclosure has to be removed and plugged back in? knubile WinNT Based 5 01-03-2005 08:39 PM
Where can i find a lcd 20x4 with led back light Dan General Hardware Discussion 1 04-28-2000 12:14 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
