09-05-2006, 08:14 PM
#1
Raw Wave
Vehicle: Chevy Van G20 and '06 Scion Xb
IG3.0 Coordinates Are Back
Thanks to Liquid Kernal Posting the .res file from his PDA version of IG
I'm Happy to report that I have added Coordinate Functionality back into IG3.0
All done with Reshacker. I ve attached a screenshot below which shows it working.
Im going to see if there are any other major changes we can adapt for this mod
You will need reshacker and some patience
Please see Below
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
09-05-2006, 08:43 PM
#2
Raw Wave
I TAKE NO RESPONSIBILITY IF YOU MAKE A MISTAKE OR FUBAR YOUR COPY OF IGUIDANCE
IF THIS SEEMS TOO ADVANCED FOR YOU IT PROBABLY IS AND YOU SHOULD HAVE SOMEONE ELSE DO IT FOR YOU
With that being said Welcome
Here is a quick guide on how to get the "Navigate by Coordinates" back into IG3.0 UMPC
Tools
Reshacker
Procedure
You will need to add a new Dialog to IG3 to do this
1. Grab the attached zip file
2. import the 1092.res file as your 1st dialog
3. Then you may either edit the 1004 dialog or simply import that as well
OPTION 1: Import
Follow steps 1 and 2 replacing 1092 obviously with 1004
See Step 7
OPTION 2: Change
4. Select the 1004 Dialog in reshacker
5. Select all text and then delete it
6. Copy the text at the end of this post
7. Go to both newly changed dialogs and click Compile Script on both
8. Goto File>SaveAs and save the new file as iGuidanceUMPC.exe
NOTE: DO NOT OVERWRITE YOUR CURRENT VERSION IF YOU HAVE NOT MADE A BACKUP
Code:
1004 DIALOG 0, 0, 183, 128
STYLE WS_POPUP
CAPTION ""
LANGUAGE LANG_ENGLISH, SUBLANG_ENGLISH_US
FONT 19, "TAHOMA"
CONTROL "Address", 500, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 3, 23, 85, 26
CONTROL "Intersection", 502, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 3, 49, 85, 26
CONTROL "Points of\nInterest", 504, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_MULTILINE | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 3, 75, 85, 26
CONTROL "Favorites", 501, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 92, 23, 85, 26
CONTROL "Recent", 503, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 92, 49, 85, 26
CONTROL "City Center", 505, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 92, 75, 85, 26
CONTROL "", 2, BUTTON, BS_OWNERDRAW | BS_MULTILINE | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 158, 1, 20, 13
CONTROL "", 506, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_MULTILINE | BS_FLAT | WS_CHILD | WS_TABSTOP, 50, 5, 85, 26
CONTROL "", 516, BUTTON, BS_OWNERDRAW | BS_MULTILINE | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 6, 1, 20, 13
CONTROL "Coordinates", 803, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 48, 101, 85, 26
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
09-05-2006, 08:53 PM
#3
Quote: Originally Posted by lostreception
I will post the code momentarily please bear with me
...and I thought I would go to bed earlier tonight
Great work!!!
09-05-2006, 09:14 PM
#4
Raw Wave
First post updated!
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
09-06-2006, 01:17 PM
#5
I imported the two .res files and it does function very well! Excellent detective work, lostreception!
I was testing it at 1024 by 768 px resolution, and as seen above, there seems to be a little aesthetic glitch. But that is a minor thing that can be likely very easily corrected.
Excellent work!
I posted a link to iGuidance Customization Ideas at http://www.gpspassion.com/forumsen/t...TOPIC_ID=28166
09-06-2006, 02:40 PM
#6
MySQL Error
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
I did it this morning to the UMPC version and so far it works fine.
Now, I want to do it to the regular version.
Okay those who are interest doing it for the regular version (iGuidance.exe) here you go.
Same disclaimer as lostreception. DO IT AT YOUR OWN RISK
Dialog 1004
Code:
1004 DIALOG 0, 0, 183, 120
STYLE WS_POPUP
CAPTION ""
FONT 10, "Tahoma"
CONTROL "Address", 500, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 3, 21, 85, 25
CONTROL "Intersection", 502, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 3, 45, 85, 25
CONTROL "Points of\nInterest", 504, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_MULTILINE | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 3, 69, 85, 25
CONTROL "Favorites", 501, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 92, 21, 85, 25
CONTROL "Recent", 503, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 92, 45, 85, 25
CONTROL "City Center", 505, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 92, 69, 85, 25
CONTROL "", 506, BUTTON, BS_OWNERDRAW | BS_MULTILINE | BS_FLAT | WS_CHILD | WS_DISABLED, 98, 94, 85, 26
CONTROL "Coordinate", 803, BUTTON, BS_OWNERDRAW | BS_LEFT | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 48, 94, 85, 25
Dialog 1092
Code:
1092 DIALOG 0, 0, 183, 120
STYLE WS_POPUP
CAPTION "Coordinates"
FONT 10, "Tahoma"
CONTROL "", 804, EDIT, ES_LEFT | ES_AUTOHSCROLL | WS_CHILD | WS_VISIBLE | WS_BORDER | WS_TABSTOP, 33, 23, 65, 11
CONTROL "", 805, EDIT, ES_LEFT | ES_AUTOHSCROLL | WS_CHILD | WS_VISIBLE | WS_BORDER | WS_TABSTOP, 33, 38, 65, 11
CONTROL "Nav", 540, BUTTON, BS_OWNERDRAW | BS_MULTILINE | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 145, 95, 34, 20
CONTROL "Fav", 501, BUTTON, BS_OWNERDRAW | BS_MULTILINE | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 145, 70, 34, 20
CONTROL "Map", 539, BUTTON, BS_OWNERDRAW | BS_MULTILINE | BS_FLAT | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 145, 45, 34, 20
CONTROL "", 2, BUTTON, BS_OWNERDRAW | BS_MULTILINE | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 158, 1, 20, 13
09-06-2006, 05:50 PM
#7
Vehicle: '98 Toyota 4Runner
awesome guys!!! i love you!
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
09-08-2006, 01:33 PM
#8
Raw Wave
what other featues do you guys regularly use
im going to make a patch for ig and a program to control most used functions
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
09-09-2006, 07:00 PM
#9
Vehicle: 2001 Ford Crown Victoria
both work EXCELLLENT!
09-13-2006, 09:27 AM
#10
Vehicle: 1986 Jaguar XJS
I have to say this is an awsome mod. I did it and it worked great. Very easy to do.
09-17-2006, 01:40 PM
#11
Vehicle: 1998 BMW M3
You RULE. I was so annoyed the other day when I needed this to get to a hiking spot.
So happy to have it back!
1998 BMW M3
Mods: Staggered SSR Competition wheels : M Roadster Short Shifter : JTD Aluminum Underpanel : Koni Adjustable SAs : Eibach Pro-kit springs : European clear corners and side markers : Hardwired V1 automatic door and radar detector
10-13-2006, 05:03 PM
#12
Vehicle: Isuzu/Rodeo/99
This mod is working for me kudoz, it wasn't that easy for me cause I am new at this site I was looking for the import function in the reshack menu couldn't find one. For all the newbies to import click on "action" then select "add new resource"
12-18-2006, 10:37 PM
#13
ok, just upgraded to ver 3.01. Dialog 1092 sortof works. It is not showiing the number buttons .
1004 works but not 1092. For version 3.01, just fyi
12-21-2006, 09:20 PM
#14
Raw Wave
i havent had time to upgrade but im beginning to hate inav
they removed that because of this mod possibly? ( i should be so flattered but... why do they do things counter productive
i bet igQWERTY is borken for sure now too
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
12-21-2006, 10:12 PM
#15
well as long as you keep 3.0 and not 3.1, the mods work.
| Thread Tools |
| Display Modes |
Linear Mode
