Old 09-06-2006, 02:54 PM   #1
Question about USB powering of the GPS receiver.
Will my GPS receiver work better if I connect it directly to the mobo's USB port rather than on a 4 port non-powered hub?
I'm assuming as long as it's locking onto satellites its working to its' full capacity.
But i've always wondered if connecting it directly to the mobo would squeeze a little more performance out of it.
Thanks!
2001 Acura CL traded for a 2006 Subaru Legacy GT
7" Lilliput Touchscreen
NANO-ITX+m1-atx
512 DDRsodimm
60g SATA Laptop HD
4x Apple DVDslot
digimoto OBDii
mS GPS
mini BT keyboard
relocated HU faceplate
acura cl is offline   Reply With Quote
Old 09-06-2006, 02:59 PM   #2
Raw Wave
Tidder's Avatar
Probably not.
It is always a good idea though to have the devices you really depend on plugged straight into the PC.
Tidder is offline   Reply With Quote
Old 09-06-2006, 03:20 PM   #3
v8 scimitar's Avatar
If its working its working I would think. Only time I could see it make any odds is if your drawing too much power from the hub but you would soon know if you were.
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit.
v8 scimitar is offline   Reply With Quote
Old 09-24-2006, 06:49 AM   #4
Goddy's Avatar
My experience is that it really helps to hook it up straight to the mobo. I once used an extension USB cable and that turned out to have less power and much worse signal. Since I removed the extension cable I have a lot better and sooner lock.
So if you are using a non-powered hub its like the same as using an extension cable.
2 options: power your hub or connect it straight to the mobo
Goddy is offline   Reply With Quote
Old 09-24-2006, 08:15 AM   #5
Neither darque nor pervert
DarquePervert's Avatar
I do believe he's talking about connecting to the USB headers on the motherboard, not a USB port on the motherboard vs a USB hub/extension.
But I agree that it shouldn't make a difference. If it's working, it's working.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 10-05-2006, 05:45 PM   #6
Goddy's Avatar
As far as I can see he said connect it directly to the mobo instead of a 4 port non-powered hub ?!
EBAY: Xenarc 700Y, GPS Receiver, USB Touchscreen Controller King_Aero Classified Archive 3 10-11-2005 04:17 AM
WTB: USB GPS receiver mykolJay Classified Archive 0 06-22-2004 11:00 AM
WTB: GPS receiver (USB) Mastero Classified Archive 2 06-18-2004 12:25 PM
HOLUX GM-210 USB GPS Receiver Deadnick GPS 2 05-19-2004 07:02 AM
