09-15-2006, 11:05 PM
#31
Raw Wave
Vehicle: Chevy Van G20 and '06 Scion Xb
If those with problems could post
1.thier resolutions
2. some system info win xp service pack 2 etc
3. anything else seeming relevant (embedded not embedded)
4. if it happens everytime or just sometimes
thanks it'll help me isolate the problems
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
09-15-2006, 11:12 PM
#32
Vehicle: '06 Triple Black Mustang
Awesome idea, cant get your app to fire though. Everytime I bring up the osk I get this error and after clicking 'ok' it crashes.
09-15-2006, 11:38 PM
#33
Raw Wave
i've experienced that as well i think i know where its comming from
please try post your system specs with any problems
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
09-16-2006, 12:01 AM
#34
I see dead kittens
Vehicle: 1998 Audi A4
good work, gonna try it out.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
09-16-2006, 12:36 AM
#35
Raw Wave
So far this works for me
Tidder
JohnWPB
and im assuming Marvin Hlavac
Is it loading properly for anyone else or is it not functioning for everyone who has downloaded it
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
09-16-2006, 12:42 AM
#36
Vehicle: 2002 Mitsubishi Galant
I noticed that it works outisde of RR. It works the first time i load iguidance in RR but after that i get that runtime error. Also i noticed with the GPS coordinated that when you enter a Lat command and Long command the top of the IG screen goes away like the X and the go back button.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
09-16-2006, 12:55 AM
#37
Raw Wave
thx for the info
the gps coords disappearing i belive is supposed to happen so you can then see the label that tell you if the coords resolve to and addressthe back button still functions tho dispite is disapperance on that page
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
09-16-2006, 01:08 AM
#38
Calm Down Or Get A 2 Week Vacation -Love The Forum Policeman
Tried it in RR. IG-Q crashed, started it again, worked over and over and over again, then crashed, restarted, worked once, then crashed, restarted, and worked a bunch of times, then crashed. I think you get the picture.
This is latest version of the RR, and with IG NOT native, XP
Wish I had more to help you.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
09-16-2006, 01:43 AM
#39
I see dead kittens
patcher does not work with modified exe.
iG stand alone, IG-Q didn't work at first, so restarted a few time now works.
In RR, get runtime error 28
Installed
09-16-2006, 08:06 AM
#40
Vehicle: 99 Infiniti Q45
Quote: Originally Posted by Tidder
Depends on the modifications made. If you modified values that were there before with values of the same length (ie 64 modified to 99, destination modified to wtf-rugoing, etc) then it will work fine. But if you've modifed anything else, added dialogs, etc, it WILL NOT WORK. You'll end up with a jacked up iG exe file.
Oh no.....any chance of getting the hacks you made so they can be incorporated with other changes that have been made to the exe (and so we can include custom images)? I'm specifically asking in relation to Justintime's IGNexus mods.
09-16-2006, 12:37 PM
#41
First, I'd like to thank LostReception for this hack. This is really neat, and will, one day, prevent me from having a big car accident I'm sure!!
While it works great on my system, I've found a small "bug" in the way it behaves when you do not type the whole streat name. This is what happen when you:
1. "type" the first characters of a street name
2. click on the name you want in the window (or use the arrows to select another name)
3. "type" OK
Normal iGuidance:
IGQ iGuidance:
With IGQ, it does not "pick" the selection done with the mouse (or the arrows), and keep the first name from the list, offering a "1-99" street number range (the one from the "TOURNESOL" street instead of the "TOURNESOLS" street).
This is not a huge problem, but force to "type" the full street name, which is some case could be cumbersome.
Not sure if it is something than can be corrected, but if yes, then that would make your hack PERFECT! If not, you may want to get rid of the "arrows" buttons and use the space for something else, as the arrows don't work.
Thanks for your great work!
André
09-16-2006, 12:44 PM
#42
Vehicle: 2005 Mazda3i
After a reboot it seems to work fine on my machine. Thanks, and great job!
MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
Currently: Enjoying the setup, but always contemplating my next move...
09-16-2006, 01:45 PM
#43
Raw Wave
André
Thank you for pointing that out ill see if anything can be done im sure ill figure something out
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
09-16-2006, 01:54 PM
#44
Raw Wave
possible temporary fix:
i think part of the stack ovewflow problem the runtime error 28 is that:
when running the program on a faster machine it executes the search for window command so quickly that it unintentinally searches too many times for vb to handle i am going to build some more error handling and work on that in the meantime you can try to slow down the code from executing so fasy by adding a debug-igq.text file to the dir that iGQwerty is in
not ice it is "debug-igq.text" not debug-igq.txt. this is actually a typo on my part and once that file is in the dir iGQwerty will create a debug-igq.txt file and log a debug file
by doing this it give it mre things to do in the meantime then fill up the stack
give it a shot it might work
if not im still working on the error handling
-Lost
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
09-16-2006, 03:35 PM
#45
Raw Wave
Vehicle: 04 Pontiac Sunfire (The Racer is dead...)
Quote: Originally Posted by lostreception
To do it Manually
Locate Dialog 1008
and change
Caption "" to
Caption "OSK"
Using reshacker. This will make your iG compatible with lost's OSK. The other thing the patch does is adds back in the coordinates dialog, but it's not needed for this.
| Thread Tools |
| Display Modes |
Linear Mode
